Threaded Hole Repair
Old Jan 18, 2007 | 07:16 PM
GTR1999's Avatar
GTR1999
Default Threaded Hole Repair
deleted
Old Jan 18, 2007 | 07:22 PM
Binnie77's Avatar
Binnie77
Excellent job indeed! Pictures are worth a 1000 words!
norvalwilhelm's Avatar
norvalwilhelm
Very good information. Thanks Gary.
I set up a set of 355 gears this past week and had a hard copy of your paper on doing this infront of me and use it as a bible. It is a great rightup and made several copies for future use.
You pass on alot of great information.
Old Jan 18, 2007 | 07:29 PM
SLVRSHRK's Avatar
SLVRSHRK
I'm always impressed with Gary's posts (and work), but that shipping crate is a work of art as well!
Old Jan 18, 2007 | 08:15 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good job!!!! i like the idea of using the vice with piece of stock clamped in it as a platform to work from.....i'm going to make me a filler piece this weekend....thks bob
Old Jan 18, 2007 | 08:26 PM
75 Hot One's Avatar
75 Hot One
Good point about using Loctite to keep the insert in place. I don't recall Heli-coil mentioning that in their literature. I'll have to do that in a job I have.
Old Jan 18, 2007 | 08:46 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
As always Gary, very nice work. Staking the insert helps in keeping the insert as well as the loctite and whatever thread lock is there to begin with. As you said, I believe it will be there for ever.
Old Jan 18, 2007 | 08:50 PM
shafrs3's Avatar
shafrs3
I like the design of those inserts.
Old Jan 18, 2007 | 09:14 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Why not just get a good used caliper bracket?
Old Jan 18, 2007 | 09:35 PM
vvette390's Avatar
vvette390
Nice job! I have a similar problem with a stripped motor mount bolt hole in the block of my 427. I was going to helicoil it but my machinist brother-in-law said a thread replacement (like yours) was the way to go. Now I know why I like that guy. I never actually saw a heli-coil fail before as was a little skeptical. You've made a believer out of me I guess I can stake the top of the threads, since the hole is blind? ...Thanks...Joe
Old Jan 19, 2007 | 10:27 AM
Crazyhorse's Avatar
Crazyhorse
I didn't even know that full inserts were available,
thanks for the info !
Old Jan 19, 2007 | 04:42 PM
Wrencher's Avatar
Wrencher
Along that same design, I used to use a different type called "Keensert" on VW drag race engines. Very similar to the ones shown, but on the outside threads they had 2-4 what I can only describe as pins sticking straight up that you drove down into the theads to 'lock' the insert. No stakeing required and I never had one fail.
http://www.newmantools.com/kee.htm
Hans
To Threaded Hole Repair
