Fuel Pump Pressure
A lot of people get carried away with the fuel pump. It only needs to get gas into the fuel bowl at a minimum pressure.
I ran mine on the dyno with a 4th gear pull from 2000 rpm to 6200 rpm and my fuel pressure stayed rock steady at 6 PSI.
One thing that has intrigued me for a while is the inertia of petrol (gasoline). If you think about it, you're idling at the lights and the pump sucks a very small amount of petrol about eight feet from the rear mounted fuel tank to the engine along a 3/8" metal pipe and everything is rosy.
Then you nail the throttle and the car leaps forward and the petrol in the long fuel line has two forces acting on it. One is its inertia, i.e. it wants to stay where it is, and the other is air pressure in the tank being slightly higher than the pressure at the pump inlet and this tries to force it forward to the engine. The petrol is being forced forward along the fuel line by (ambient) air pressure in the tank while everything that is not bolted down is being forced backward by the forward motion of the vehicle while it is accelerating. Including the petrol in the main fuel line.
This could lead briefly to a lack of fuel (or air) at the inlet to the pump while the petrol is fighting its inertia. The result could well be a brief flat spot due to there not being enought fuel available to feed the engine while under harsh acceleration.
To overcome this problem, (if indeed there is one!!!), one would need to have a fuel tank mounted ahead of the engine so that under acceleration, the petrol would be forced rearward to the pump pick up and there would be no starvation. As this only occurs under harsh acceleration, which is usually in the lower gears, only a small or supplementary fuel tank would need to be fitted up front.
While the car is cruising, the inertial forces of the fuel are similar to when the car is stationary and there is no starvation. Only when accelerating. I'm not a scientist and this is only a theory. What do you think?
Regards from Down Under
aussiejohn
The pump in there now is just a new standard BB pump. Not a corvette specific or heavy duty. I do have an edlebrock HP pump, but am hesitant to use it since there is no return line provision.
Works perfectly for the 350. drilled return line to .035". Still gets more than enough for sustained WOT.
Someday will drill and tap for a pressure adapter like as in a FI fuel rail to connect test presure gauge, but couldn't find them in my mess.
More people overcome needle and seat with too much pressure and create flooding condtitions than starve for gas.
Hvymtlc5, i don't know what your measuring fuel press with but most of those tiny in-line gauges are junk. If u don't have a hand held test gauge then only use the non-filled (no liguid filled) type in-line and average the readings.
A dead ended fuel line to the carb is always a problem to measure as the internal relief fights the carbs needle and seat at idle.
aussiejohn, your think'n ahead and the real fix for hard launches is to mount an electric pmp behind the fuel tank. But for most of us the stock sys does fine as long as the fuel line has no sharp bend, turns, restrictions etc. With <400rwhp (my guess) just race with a full tank for the extra press head and u will be fine.
cardo0
