Poly vs Rubber Bushings
Old Jan 21, 2007 | 10:33 PM
Bob3700's Avatar
Bob3700
Default Poly vs Rubber Bushings
I have a 1970 that I occasionally drive on the street. Just a toy that I have had since 1973.
Am in the process of replacing some of the old cracked rubber bushings in the front and rear sway bars and the rear shock mounts. Will probably replace all the front a-arm and rear trailing are bushings next Winter.
In the past (15 yrs ago) I avoided the poly bushings as I considered them a little too performancy. Don't want any increased harshness in ride, no increase in noise, etc.
What is the current thinking on present bushing replacement. I am NOT restoring to NCRS specs, just trying to keep my car original while maintaining a decent ride. The poly bushings I know will outlast the rubber. The car is an HP 454 with 4 spd.
Thanks for your input.
Bob
Old Jan 21, 2007 | 10:54 PM
SIXFOOTER's Avatar
SIXFOOTER
I have always been a fan of Poly. I put it on my 77 and again on the 81 I am building. It does impart a little more harshness but it also gives you a LOT more road feel and control. Some guys like it some don't.
Old Jan 22, 2007 | 10:12 AM
jackson's Avatar
jackson
Any NEW bushing (poly or OE Rubber) will stiffen a car that had worn/soggy bushings.
Following regarding ONLY front control arm bushings:
OE (rubber) can be difficult to remove and new OE must be pressed back into arms. Remove/Install via press can damage/bend CA if CA is not well supported.
Poly can be MUCH simpler to do. If your OLD OUTER steel shells are not damaged (probably not) they can be reused without problem ... if OK, they need NOT be pressed out or cut out and should be left in place. Hog out the old rubber w/ a $7 hole saw & a penknife & carb cleaner. Throw away the old inner steel sleeve. Do not use the new outer shells that come w/ poly kit. Install the new inner steel sleeve onto the old (but clean) shaft end & install new poly bushing into the old (but clean) outer shell ... use plenty of silicone GREASE throughout assembly. Once poly bushings assembled, spritz out the shafts' end threads w/ carb cleaner ... very clean & very dry ... & install clean end bolts w/ loctite. I did this procedure some 5-6 years ago using energy suspension brand poly CA bushing kit ... same C3 still on the road & current owner pleased.
Old Jan 22, 2007 | 12:00 PM
markdtn's Avatar
markdtn
I have poly on mine, just a driver. It rides fine. No squeaks, not harsh.
Old Jan 22, 2007 | 12:05 PM
Twin_Turbo's Avatar
Twin_Turbo
Since the trailing arm goes through a complex motion poly is not really suited for that bushing. As the susp. moves the toe chnages and the arm not only moves up and down rotating the bushing but it all moves the arm sideways deflecting the bishing. Rubber is much better suited here.
Old Jan 22, 2007 | 01:10 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Everything in my front-end is poly. As far as the ride goes, C3's ride so rough I never noticed a difference.(mine don't squeak)
Larry
Old Jan 22, 2007 | 01:27 PM
karioth's Avatar
karioth
im re-doing mine with poly.
Old Jan 22, 2007 | 05:07 PM
ajrothm's Avatar
ajrothm
I went back with rubber in mine because ever car I have put poly in squeaks its a$$ off after a month. No matter how much grease you put on the bushings at assembly or how often you grease the zerks, they still freakin squeak. Now if I was building a handling machine to corner carve I would use poly but on a cruiser, use rubber. They last plenty long. How long did it take for your originals to wear out? 20-30yrs? If I have to replace em every 20 yrs, I can live with that. LOL
Old Jan 22, 2007 | 05:09 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Your rubber ones lasted over 35 years. Mine lasted over 35 years before replacement. I figured that if they lasted only 30 years this time, they will have outlasted me. I suggest rubber but do what you want.
Old Jan 22, 2007 | 07:47 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Weird. I've never had that happen.
35 years?!? The rubber bushings on my 77 looked like hell when my dad bought it in 91.
Old Jan 23, 2007 | 10:34 AM
Big2Bird's Avatar
Big2Bird
Old Jan 23, 2007 | 10:57 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Just like our avatars, we have two different cars. Mine were cracking when I redid it, but they weren't toast.
And with regards to poly- if I had a second, NOM, built for speed C3, I'd go poly. But then I'd go EFI, Keisler, big old Dewitt's Aluminum radiator, all that good aftermarket stuff, etc., just for the pure he77 of it, and to beat the he77 out of it. In some ways, I envy those who could care less about originality. Either way, though, our C3's are fun to drive.
Old Jan 23, 2007 | 12:24 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think you got lucky. The rubber bushings on my '00 Cherokee are already well-cracked...
Old Jan 23, 2007 | 12:27 PM
greyghost79's Avatar
greyghost79
ah, the old rubber versus poly argument. lol.
people on this forum seem divided and very opinionated on this question. i replaced my 79 control arm bushings with poly. while i feel it really improved the handling THEY CAN BE NOISY especially at low speed going over speed bumps, up driveways, etc. if that won't bother you then go for it. they will last and last. rubber bushings will probably do fine also and be quieter. to each his own.
Old Jan 23, 2007 | 02:46 PM
karioth's Avatar
karioth
they will last that long if you park indoors and live in a climate stable... warm area
To Poly vs Rubber Bushings
