Holley Carb Hesitation Again
The first thing that you need to do is adjust your float level, no fuel should run out the sight plug with the engine running. and check to make sure that your fuel pressure is not over 7 PSI. I suggest 6-6.5 PSI Make sure the acc. pump is properly adjusted. It should be at zero lash at idle. and have at least .015" gap at Wide open throttle with the pump lever pushed all the way down. Then try turning in the idle air screws all the way in with the engine running. If the engine continues to run with both screws all the way in, then the carb is letting fuel into the engine from someplace other than the idle circuit. We have to find out where from and correct it (with the screws all the way in the engine should die) Next you want to check the manifold vacuum with the engine idling in gear. This will tell you which size power valve to use. If your vacuum is 9" and under divide by two, and that is the size you need. If it is 10" and over use a 6.5 PV. You may have to replace it with the correct size. If you get all of this corrected and the engine still runs rich then you will probably have to remove the carb and adjust the secondary throttle plates open to the bottom of the transfer slots. This will allow you to close the primary plates down some. If either plates are open too far then fuel will be pulled in to the engine from the transfer slots in the base plate. By adjusting those plates like I said, the carb will get the same amount of air at idle, but it will get it evenly from the front and rear instead of just the front. Once you get it so the engine dies with the idle air screws, then you can continue with the rest if the adjustments. Next you need to adjust the idle air screws. Turn them in until they seat lightly then back them out 1.5 turns. Start the engine and let it warm up. Hook up the vacuum gauge to manifold vacuum. Check it at idle in gear. Adjust the idle air screws evenly until you get max vacuum (the vacuum will drop off if you go to rich or lean) With that done you can start working with your jetting Unfortunately I can't tell you how to jet it. Each engine is different and has different requirements. It is a trial and error process. Start with the stock jetting and go from there, Run the engine under a load and read the spark plug color to find out which way you need to go. Black is rich and white is lean. It is best to tune the primaries first at part throttle and the secondary's at WOT run the vehicle at least a quarter mile and shut it down under throttle in order to get an accurate plug reading. This should be accomplished on a track or a long stretch of road with a wide shoulder that it can be done safely.Adjust it until you get a nice light brown color on the porcelain of the plug. when you get this adjusted . If you have a off line hesitation that is less than a second Increase the shooter by one size. If it is over a second increase the shooter by Two. If it makes the hesitation better you can increase accordingly if it gets worse drop the size.
Thanks Tom
Also according to holley the stock primary jets are 70 and the seconday is a 21 plate.
Motor is a yearone roller motor 350 vortec heads 9.5:1 compression, rpm air gap manifold.
Any more help on this is appriciated Sorry for such a long post and the questions.
I had a bad hesitation with mine when I got it.
I checked and I don't recall the sizes off the top of my head, but; the jets in mine were too small.
Mine is a 650dp. I looked it up on Holley's web site and then ordered the factory jets for it. When I installed them, the problem went away.
I don't know if your problem is that simple, but; it is worth a look.
good Luck!!
I would from start to finish, paying close attention to the opening of the throttle plates and possible adjustment of the secondary plates.
Thanks Tom
2). Also where do you live so I can relation to sea level.
3). What kind of intake?
4). What was your intake vacuum in gear at idle?
5). What is your intial timing set at with what camshft?
I have to run at least a 73 on the primary. I played with my quick fuel carb for months until I went up to a 74 jets on my primary and 80 jets on my secondary. Also I went down to a 3.5 power valve.
Follow their recommends and you'll be fine.
I have a Holley 570 cfm on my base 350 and had the same problem until I figured out that the cam follower wasn't close enough to the cam. Bent it - problem solved.
A friend called to question why I would bend the cam follower (accelerator pump lever) rather than just adjust it. Well the answer is that I had no adjustment left. The Nyloc nut was at the end of the threads and the tension spring was loose and still the cam follower was nowhere near the cam. If, when you push the pedal down to 1/4 throttle and you're just starting to get accelerator pump, it hesitates big time.
Lars has stated in numerous threads that carburetors when new, need serious work before you use them. After having this problem and also a leaking primary inlet valve that caused fuel to run uncontrolled into the engine, I know he's right.
BTW, the car now runs GREAT!
There are two settings for the cam. setting 2 will allow a faster and bigger squirt. This may help also.
Have been working on my 71, thank goodness for my original 72, it's my go to for info.
I just rebuilt the power window relay, he had the feed wired directly to the battery?, from the switches.
He had the car from 88, guessing he never replaced a part, just "fixed" things.
Last night
I rebuilt the high speed relay for the blower motor. 2 broken tabs. don't ask.....it will be a 383 and 5 speed when done. yes it's matching numbers. but the 72 has 22,268 miles.
Last night
