Gary, question 81 rear.
Old Jan 21, 2007 | 01:48 PM
Big2Bird's Avatar
Big2Bird
Default Gary, question 81 rear.
Gary, thinking about adding a drain plug to my 81 rear. Where do I want to put it? Suggestions?
Old Jan 21, 2007 | 03:51 PM
GTR1999's Avatar
GTR1999
If you are calling on me, I can't help with that one. I only work on the 63-79 iron units. With them I tap the housing 1" beyond the strut bracket pad. It puts the hole in a low spot in the diff and works good.
If you do tap a hole, I would use a 1/4 x 1/8 npt brass bushing instead of a straight plug. constant use may strip out the threads in aluminum but holding the 1/4 npt bushing and removing the 1/8 plug will not stress the aluminum and give you long life. I did this with my Muncie 30 years ago and haven't had a problem since.
Old Jan 21, 2007 | 03:54 PM
Big2Bird's Avatar
Big2Bird
Thank you sir. Given your answer, I think I will use a suction pump this time around.
To Gary, question 81 rear.
