Headers 82 CE
Old Oct 3, 2001 | 09:02 AM
HarleyBob's Avatar
HarleyBob
Default Headers 82 CE
Hey guys..
Want to put headers on my 82 CE, right now I have true duels with Flow Masters.
Understand the limitations of the 82 Computer so my question is, is it worth the effort?
Old Oct 3, 2001 | 11:13 AM
82dukman's Avatar
82dukman
Default Re: Headers 82 CE (HarleyBob)
Harley, can't answer you but I have a question. I have an 82 CE and was thinking about true duals too. Did you have to change the crossmember to get them so they don't scrape :confused:
Thanks for the reply :seeya
Old Oct 3, 2001 | 03:45 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Last year, while removing some unnecessary pumps and related plumbing from my '82, I modified my cat and added K&N Airfilters. The end result was a little louder exhaust, maybe a little better top end, but definately less low end torque. After that I put on a set of Heddman Headers, true dual exhausts (with boths sides routed under the passenger side), and turbo mufflers. The result was that it still had the same power on the top end but more bottom end power than before I modified the cat or after.
Johnny
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Headers 82 CE (82dukman)
No -- mid-america makes a set that will work with the current configuration. However, you can not run the cats. with their true dual setup.
Old Oct 3, 2001 | 04:26 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Headers 82 CE (BSeery)
I have an 82 w/ 2&3/4" duals. I have hedman 63200 (non emissions legal) headers and custom bent pipes running through an early style crossmember. You need to mod it a little to fit the tranny mount.
Marck
Old Oct 3, 2001 | 09:17 PM
Wrecked82's Avatar
Wrecked82
Default Re: Headers 82 CE (Twinnie)
Twinnie
Are you sure yours is an 82?
:rolleyes:
To Headers 82 CE
