Wacky Speedometer
Old Jan 22, 2007 | 09:58 PM
Marcusk408's Avatar
Marcusk408
Default Wacky Speedometer
My 82's speedometer needle has been driving me crazy. It used to bounce a wee bit so I lubed the speedo end that goes to the transducer. That cured it for awhile but now it's even worse. Two days ago the needle started bouncing as much as 20mph up & down, sometimes less. It becomes steady once I reach 75mph on the freeway. I removed the cables (upper & lower) inside their sheaths and lubed them this weekend and it's still bouncing. What else should I check?
Old Jan 22, 2007 | 10:24 PM
Durango_Boy's Avatar
Durango_Boy
It's probably the speedometer itself. It may need to be serviced.
Old Jan 22, 2007 | 10:35 PM
Big2Bird's Avatar
Big2Bird
Ever had the transducer serviced/rebuilt?
Old Jan 22, 2007 | 10:49 PM
Marcusk408's Avatar
Marcusk408
No I haven't. Maybe I should since my cruise control doesn't work either.
Old Jan 22, 2007 | 11:18 PM
80vettefan's Avatar
80vettefan
i have seen this happen before, the speedometer cable is twisting. it's eventually going to break. i would replace the cable from the transducer to the speedometer.
Old Jan 23, 2007 | 12:15 AM
Big2Bird's Avatar
Big2Bird
I would. When I had mine done, my needle bounce went away.
Old Jan 23, 2007 | 12:20 AM
Marcusk408's Avatar
Marcusk408
Good to know. I guess I'll change the transducer. Might as well kill two birds with one stone. Been wanting to get my cruise control working again anyway.
By the way, I noticed you're from Anaheim. I used to live there from '83-'98. Class of '88 Katella High. I miss So Cal.
Old Jan 23, 2007 | 12:24 AM
Big2Bird's Avatar
Big2Bird
Kill 2 birds? Well, as long as it isn't big2bird Anaheim High, '73
Old Jan 23, 2007 | 12:28 AM
Marcusk408's Avatar
Marcusk408
LOL Didn't even make the connection when I wrote that.
Old Jan 23, 2007 | 10:28 AM
Durango_Boy
Or Birb2bird. He would appreciate that at all.
Old Jan 23, 2007 | 10:57 AM
bob_robert's Avatar
bob_robert
Default Probably it's the Transducer
My 78 speedo did the same thing. It was the transducer. I don't need cruise so I took the tranducer apart, cleaned it and removed it's guts. Speedo works fine now.
If you want to try and fix yours at home go to http://www.nottingham.ac.uk/~eaztl1/...trol_recon.htm.
I used to live in The City of Orange from 78 to 84, still have family there.
Old Jan 23, 2007 | 11:50 AM
Big2Bird's Avatar
Big2Bird
Nice posting. Good info.
Old Towne Orange is a nice area.
Old Jan 23, 2007 | 06:40 PM
VCuomo's Avatar
VCuomo
I work in Anaheim, and live a few miles from Old Towne Orange. Lived in OC since 1974.
Old Jan 24, 2007 | 12:46 AM
Marcusk408's Avatar
Marcusk408
Thanks for the link! Very informative. I'll try fixing it myself this weekend.
To Wacky Speedometer
