Odometer accuracy with different tire sizes?
Old Jan 23, 2007 | 09:49 AM
smoothsailing's Avatar
smoothsailing
Default Odometer accuracy with different tire sizes?
Non stock tires sizes will alter odometer accuracy. Any formula to figure the correct speed based on new tire size?
Old Jan 23, 2007 | 09:56 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Let me know the old and new tire size and I'll get you the numbers..
You could also sign up at:
http://www.smokemup.com
and use the calculators
Old Jan 23, 2007 | 10:04 AM
Big2Bird's Avatar
Big2Bird
http://www.700r4.com/speedoCalc/speedocalc.shtml
Old Jan 23, 2007 | 11:57 AM
Big2Bird's Avatar
Big2Bird
I do like the way you worded this statement. Alot of people do not realize, you adjust gears for odometer accuracy, not speed. The gears determine the odometer, then the head is calibrated to the correct cable speed.
Old Jan 23, 2007 | 01:15 PM
sperkins's Avatar
sperkins
This site will tell you exactly what will happen:
http://miata.net/garage/tirecalc.html
Old Jan 23, 2007 | 01:23 PM
PRNDL's Avatar
PRNDL
I like this tire size calculator:
http://www.miata.net/garage/tirecalc.html
With all the info it gives you, they also include a little note below:
Speedometer reading with non-stock tire is 23.5% too fast. When your speed reads 60mph you are actually travelling 45.9mph
This is exactly the info you are looking for!
Old Jan 24, 2007 | 10:13 AM
smoothsailing
The tires I'm running now are 265/50/15 on stock rims. Thanks for any info.
Ed
Old Jan 24, 2007 | 12:47 PM
RadicalPursuit's Avatar
RadicalPursuit
Default Gps
I like to check the speed with a handheld GPS. Nothing like ground truth.
To Odometer accuracy with different tire sizes?
