Compression Calculator Help
Old Jan 23, 2007 | 09:53 AM
SoCalErv's Avatar
SoCalErv
Army
Default Compression Calculator Help
Cran Cams # 11350 has the following information on their spec sheet.
Cam Timing Tappet @.50
Lift Opens Closes Max Lift Duration
intake (4.0) ATDC 30.0 ABDC 107 206.0
exhaust 46.0 BBDC (8.0) BTDC 117 218
On the compression calculator it ask for this input:
Intake - closing point (degrees) ABDC@.050 Lift plus 15 degrees.
Do I take the 30.0 ABDC add 15? I am lost please help
Old Jan 23, 2007 | 12:57 PM
SoCalErv's Avatar
SoCalErv
Army
Come on GearHeads give me a little help.
Old Jan 23, 2007 | 09:03 PM
SoCalErv's Avatar
SoCalErv
Army
ttt
Old Jan 23, 2007 | 09:53 PM
dgruenke's Avatar
dgruenke
Yes, you are correct.
Old Jan 23, 2007 | 10:05 PM
SoCalErv's Avatar
SoCalErv
Army
So the number for this input cell with the example provided would be 45 degrees?
Old Jan 23, 2007 | 10:08 PM
dgruenke's Avatar
dgruenke
Yes, but if you are using the KB compression calculator, it tends to give a slightly high reading on the DCR.
To Compression Calculator Help
