The year is a 76 and the engine is a 350 thats all I know about it,,,wouldnt that be a L-48 I think that is what is on the console plate,,,I could go look if need be,,,its out in the shop back of the house.
If it's an L-48 it's a 2-bolt main, which means 'L' motor...I think.
Your kidding right?
That's one of the gifts from the Chevrolet Gods about these cars, you can drop the pan without going through all that B.S.
That's what I thought at first, but I tried unbolting the idler arm, and that was a PITA. I didn't want to separate the tie rod end, so I gave the mounts a shot and it went smooth and fast. A jack, a ratchet, and viola. Lifted and in prolly ten minutes I was half way through the pan bolts.
