I just totally rebuilt my 350 in my 74 vette and when I start it the oil pressure guage pins past the 80 psi mark and blows the dipstick out and oil as well. What could be the problem?
I used a melling high volume oil pump but that shouldn effect the pressure, should it?
I didn't run the engine long to seat the ring, it was blowing oil and the pressure was too high so I shut it down.
I have the same pump and also get 80+ psi, if your blowing the dipstick then the block is pressurising. This could be due to blow by from new rings not yet seated properly or you need more breathing from the rocker covers. Are you running a pcv valve or a large rocker cover breather?
Well you can't get better breathing than that! The high oil pressure would not be the problem with the popping dip stick, the only thing that can do that is excessive pressure in the block while the engine is running. If this is a brand new start up motor then you must be getting a lot of blow by from the rings. Is it pushing oil out through the dip stick tube?
How can you get enough crankcase pressure to blow the dipstick out if both rocker cover vents are open and the oil drain holes in the heads are open to the crankcase?
I would not have thought that was possible? What do you think?
Could wrong head gaskets seal the crankcase or gaskets incorrectly installed?
Yes it will. When I got my car it also had a melling HV pump on it and it buried the gauge when cold and still had excessive pressure hot. The HV pump is +20% volume and all that extra oil still has to go through the same size passages = more pressure. I switched to a normal melling pump and the pressures were fine, 30 PSI hot idle and 60 PSI at high rpm.
It does sound extreme. Maybe the valve covers are baffled and that creates enough of a restriction to build pressure? I know people that break piston ring lands will blow the dipsticks out so it's certainly possible.
Cheers,
Joe
If the rings were not set properly then there will be little sealing. I did it on my first engine and it had so much blowby it puffed like a train. Ran like crap too.
Thanx everyone for all you help and ideas. I was a fresh rebuild but the only stock part was the block. .030 over, 480 lift comp cam, 64cc dart iron eagle heads, scat crank and rods. it should be about 400-425 hp. The problem was with the dipstick was because the rings weren't seated yet. I have a 7 quart oil pan and took about a quart out and that stopped the blow out. Thanx again for all you helpful advice.....
Happy cruisin'
I'm running a 10% higher volume melling pump on my 383. my gauge read fine on my fresh motor until about 3-4 weeks after driving it......after that, it began to read around 80 and a few starts/drives later it was pegged out all the way.
i pulled the sensor and cleaned up terminal and worked fine for a few days....now it's pegged out again.....
I think that people get fixated on having high oil pressure.
Most pro-racing engine builders will tell you that you need 10 psi for every 1000 rpm on the engine. That is more than enough to keep the SB or BB engines alive.
Going to HV or HP pumps does two things:
Takes more HP do drive
Adds additional heat to the oil
Oil seals have to work harder to keep the engine dry
Unless you have a special application, road racer, serious drag racer, the stock pumps and pans work very well.
Guess that is why the aftermarket is so successful. All of we gearheads think that we can engineer the car and engine better than a multi-million dollar manufacturer.
If it is on the street, stock stuff goes a long way.
