Decode Block Number Please
Old Jan 25, 2007 | 10:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Decode Block Number Please
Can anyone confirm that I'm doing this right?
3970010, J-10-3
010 High tin block
J - October
10 - 10th
3 - 1973
Old Jan 26, 2007 | 11:18 AM
dgruenke's Avatar
dgruenke
I cannot help you much on the date code, but I don't believe the 010 at the end of the block casting number is the high nickel block. Most 350's in the mid-70's had the 3970010. I believe the way to tell if it is a high nickel block is that there will be a 010 on the front of the block, behind the timing cover.
Old Jan 26, 2007 | 12:41 PM
CA-Legal-Vette
I wondered about this. Seems like every block that I looked at had the 0010 number on it. I couldn't see why every one that I saw was the rare and desirable high nickel, high tin version.
Thanks for clarifying.
Old Jan 26, 2007 | 12:45 PM
DR.Jay's Avatar
DR.Jay
Try this link:
http://www.nastyz28.com/sbchevy/sblock.html
Old Jan 26, 2007 | 05:44 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Not sure of this but I seem to recall that the earlier 0010 blocks that were the high tin blocks had a wide but narrow number pad. (010) the later 0010 blocks had a shorter but deeper number pad. It is not something you might spot looking from one block to another but once you are aware of the difference it is readily noticeable.
Old Jan 26, 2007 | 07:24 PM
JackDidley's Avatar
JackDidley
http://www.mortec.com/castnum.htm
Lots of good number info here.
To Decode Block Number Please
