Changing PS Hoses...Any Pitfalls
Old Jan 26, 2007 | 07:40 PM
Tonys96's Avatar
Tonys96
Default Changing PS Hoses...Any Pitfalls
Going to change all four PS hoses tomorrow...1979 L-82 With A/C
Just got the new set from Wilcox, good quality hoses $43.56 for the set.
Enough of an advertisement...does anybody have any does and don'ts, read the shop manual and it just says change them and to put a new hose clamp on the return line, that's it.
As far as bleeding, shop manual says just fill let sit for 2 minutes then turn full left and right 4-5 times, let the fluid settle then refill reservoir.
Does anyone else have the same problem as I do, the PS reservoir cap won't come off without removing the alternator and alternator mount bracket ?
Old Jan 26, 2007 | 08:09 PM
Corvette Charlie's Avatar
Corvette Charlie
Cap not coming off? Sounds like you have the wrong size belt on your ps pump. As for the hoses just make sure you use The real hose wrenches and dont over tighten.
Old Jan 26, 2007 | 08:12 PM
pik's Avatar
pik
As long as I dislocate my wrist, I have no problem taking off the cap. Turn the wheel from side to side to help with the bleeding.
Old Jan 26, 2007 | 08:19 PM
Duke94's Avatar
Duke94
You pretty much have it, nothing real difficult other than getting to the tube nuts on the pump. Of cource use the correct tube nut wrench not just an open end wrench or you'll round off the nut. Look over Jim Sheas papers (link below). About half way down are the ones on hose changes.
http://jimshea.corvettefaq.com/?page_id=4
Old Jan 26, 2007 | 09:18 PM
Jim Shea's Avatar
Jim Shea
I also just posted two new papers on "getting the air out."
With the front wheels off of the ground and your engine OFF, when you rotate your steering wheel full lock to lock the assist cylinder will actually act as a pump. It will move oil and large air bubbles through the power steering circuit. When the bubbles reach the pump they will rise into the reservoir and escape to atmosphere.
There is a bit more information in the papers. You might want to take a look at them.
Jim Shea
Old Jan 26, 2007 | 10:12 PM
speedreed8's Avatar
speedreed8
i am going to do the same thing soon, change all the hoses, i thought it was interesting that he couldnt get the power steering pump cap off, because i cant either on my 79 also., unless i loosen the altenator.
what gives, wrong size belt?
Old Jan 26, 2007 | 10:13 PM
Tonys96's Avatar
Tonys96
Jim Shea
Thanks, I was just reading them, I like the idea of not running the engine as my filler cap is obstructed by the alternator bracket. Could be a combo of the DART heads and maybe needing a better pulley alignment, but it sounds like just the ticket for me.
And it'll be a few months I imagine before the salt is off the roads in Minnesota so I imagine that most of the entrained air will rise to the reservoir by then.
Thanks all.
Old Jan 26, 2007 | 10:16 PM
Tonys96's Avatar
Tonys96
My belt can be off and I can move the power steering pump through it's full range of adjustment and still can't get the cap off.
I've only had the car for about a year, the PO may have changed pumps, but the belt is the correct one. For a '79 that is.
The brackets all look like the correct ones, may be something with the aftermarket heads...dunno. But it makes it a PIA to check the PS fluid, that's why I'm changing the hoses.
Old Jan 26, 2007 | 10:43 PM
SIXFOOTER's Avatar
SIXFOOTER
change it out for a C4 pump with seperate resevoir
Old Jan 26, 2007 | 10:53 PM
Attfay Elleybay's Avatar
Attfay Elleybay
I just got my hoses today. changing them tommorow. It was $64 at ecklers for all four (but backordered), I just ordered the two I needed. $17 each.
Old Jan 27, 2007 | 04:00 AM
Oldguard 7's Avatar
Oldguard 7
I took off the PS pump back in July 2000. I decided to put it back on after 6 years ( this past August) I have no leaks from the pump (I still find this hard to believe) I also replaced the power cylinder and the control valve. The original fittings were a bear for me to remove, but I got it done. New hoses went on with no problems. Followed procedure in service manual and voila, power steering again.
Old Jan 27, 2007 | 07:37 AM
C3 4ME's Avatar
C3 4ME
Ya'll must be reading my mind. I also have a 79 L-82 and the pump is currently off the car while painting/detailing the engine and compartment. I too will be replacing all the hoses when it goes back together. BTW, I can check my power steering with the alternator on. It's not easy, but it can be done.
Old Jan 27, 2007 | 08:20 AM
marshrat99's Avatar
marshrat99
My 79's cap is not too bad to get off but isn't as easy as I'd like. Sounds like a good ole GM engineering feature. As others above have said, nothing really special to consider while replacing the hoses. I had to do mine 2 times before I realized that cheap hoses were'nt the correct route. Sometimes you have to throw good money at the problem to keep it from recurring.
Old Jan 28, 2007 | 08:51 PM
Sayfoo's Avatar
Sayfoo
On my 69 BB, 1 of the offset braces that is just above the cap can be installed reversed. When I turned it over, there was more room.
Old Jan 28, 2007 | 09:29 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
The P/S cap comes off, just not straight out as you'd like it to. it is a wierd configuration to say the least.
To Changing PS Hoses...Any Pitfalls
