Brake Caliper Question
Old Jan 27, 2007 | 05:19 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Brake Caliper Question
I am having difficulty putting new brake pads on my 79. Were the factory calipers spring loaded? Anyway, my mechanic said that the best way to do it is to take the caliper off. The brake lines are not flexible. Is it safe to bend the line slightly?
Old Jan 27, 2007 | 05:35 PM
Bob3700's Avatar
Bob3700
Default A little is OK
The factory hard line that connects the caliper to the system may kink if you bend it too far. The aftermarket brake lines are made from a more malleble material and will tolerate some bending when removing and installing.
The pistons DO have springs behind them, though they are not real powerful.
The pistons just have to be fully retracted back into their bores. What brand of brake pads did you get? Never put anything but a Delco pad on a Corvette so don't know how other brands are dimensionally.
Good luck.
Bob
Old Jan 27, 2007 | 07:04 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
You can change the pads without taking the calipers off, But it helps to have this tool from Vette Brakes. http://www.vbandp.com/detail.aspx?ID=33
Old Jan 29, 2007 | 08:03 PM
SEVNT6's Avatar
SEVNT6
Right on. This tool is the only way to go. And it's cheap!
To Brake Caliper Question
