Help Identify This Radiator ...
Old Jan 28, 2007 | 01:34 PM
PinHead's Avatar
PinHead
Default Help Identify This Radiator ...
This is on my 71' L48. The inlet and outlet are different than in my AIM. Also the bottom posts are off about 1/4" from the rad suppoort scockets
looking up
Old Jan 28, 2007 | 02:18 PM
Durango_Boy's Avatar
Durango_Boy
That radiator could be out of anything...and it may not even be a GM radiator. Unless you can get some kind of a part number off of it...I doubt anyone will have a specific answer. I could be wrong though.
Either way...ditch it, and buy a Dewitts.
Old Jan 28, 2007 | 06:32 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
It's not an original Corvette radiator, but rather a copper replacement for the (GM3155316) aluminum unit. I'm not familar with an L48, did you mean L46 (350/350)? The pin mounted aluminum radiator was used on base models only, meaning no AC, no Auto, and no RPO engine. So if you think that is the original core support your car might have been a base car with no options. The pins are sapposed to be exactly 11" apart so it might be the aftermarket radiator that doesn't fit or it could be the core support is slightly bent. We have several options as far as a new radiator depending on if you want to keep the existing core support or convert it to something else. This is what the oe unit looks like
Old Jan 28, 2007 | 06:35 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanks for the plug
Old Jan 28, 2007 | 06:37 PM
Durango_Boy
Originally Posted by Tom DeWitt
Thanks for the plug
No prob. He's at the point where a good decision needs to be made, and that would be for a good radiator that will outlast the rest of the car.
Old Jan 28, 2007 | 08:09 PM
PinHead's Avatar
PinHead
Yep, I have a DeWitts in my C5 and use waterless coolent, Love it. I'm not sure how I'm going on the C3 lots of things to fix at this point in time and I'm just not ready to do the radiator yet.
Old Jan 28, 2007 | 08:28 PM
72LS1Vette's Avatar
72LS1Vette
That radiator looks like poop, but at a minimum you should seal up the areas between the radiator and the support. Get some foam rubber and seal up the gaps and that will help force the airflow through the radiator instead of around it.
Rick B.
Durango_Boy
Rick B.
That alone will improve cooling.
Old Jan 28, 2007 | 09:28 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
A good alternate to the above restoration model is the aluminum replacement we make, A63M. Not quite as good as the real one but still 25% better than anything made in copper.
Old Jan 28, 2007 | 10:11 PM
PinHead's Avatar
PinHead
Do you have a direct fit one that would provide enough cooling for AC if added it later on?
BTW yes it is an L46 base
Old Jan 28, 2007 | 10:15 PM
Durango_Boy
Wow those look really different then the radiator I would put in my '77.
Old Jan 28, 2007 | 10:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
That looks like a 4 row (bb)
I wish I had a 4 row.
Old Jan 29, 2007 | 07:04 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Engines are like snowflakes...no two are alike. I know many people that have identical cars with identical options and totally different results with the same radiators.
We are the only company that publishes heat rejection rates on each radiator and we do this because A: we know what they are B: so customers can make an educated decision. So lets look at the two above radiators. The original (Restoration type) is rated at 4600btu/min and the replacement (Direct Fit ) is 4100btu/min or about 10% less. The copper unit you currently have is rated at about 3300btu/min, assumning it is a 4row.
Now, will the 4100btu cool your car? Maybe but it is a downgrade. I have many people using the A63 with AC and working fine. Cooling is also very dependant on the local ambient air and I usually use three items to help make the decision on the downgrade. The three items are 1. HP 2. AC 3. Climate So if someone has a high HP engine, with AC, and lives in Arizona I wouldn't go with the Direct Fit. Another helpful feedback item would be what kind of temps you are hitting with the copper unit now. If the copper unit at 3300 is doing pretty good, that would mean you have a low heat generating engine and adding the AC won't hurt to bad. I hope that all makes since
Old Jan 29, 2007 | 07:15 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
They are totally different. The C3 era had many (5) different models.
The application above is a little unique because the original radiator was already aluminum. A very good aluminum plate design and no matter what I do, I couldn't make a better one. In this case, the Direct Fit aluminum is actually a slight downgrade because we are going from PLATE ALUMINUM to TUBE ALUMINUM and you lose some core surface due to the addition of the end tanks. The Direct Fit model on any other C3 model is a major upgrade because we would be going from COPPER to ALUMINUM. I just want to explain that in detail before someone assumed that all Direct Fits were downgrades.
Old Jan 29, 2007 | 08:28 PM
PinHead's Avatar
PinHead
When I bought the car in November it was in boxes so I'm just now getting it back together and running and it's somewhat cool here in Atlanta so I don't have a good gage of how the current radiator is cooling. I'll see how well it works come summer, it gets hot down here. Like I said I have one of your radiators in my supercharged C5 and it never gets over 220 even in the middle of the summer.
thanks
Old Jan 29, 2007 | 08:31 PM
Durango_Boy
thanks
Don't the new cars have t-stats that don't even open until after 220?
Old Jan 29, 2007 | 09:34 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Actually they're 190 but the fans are really the regulator. They don't kick on until 228
To Help Identify This Radiator ...
Old Jan 29, 2007 | 09:37 PM
Durango_Boy
Gotcha. I was right but with the wrong device. Thanks.
Old Jan 30, 2007 | 08:48 AM
PinHead's Avatar
PinHead
When I added the supercharger I changed the T-stat to 160 and reprogrammed the fans to come on at 200.
Old Jan 30, 2007 | 10:40 AM
Durango_Boy
Gotcha. I like how the fans have a different operating temp than the T-stat.
