racing lightweight batteries
thanks/Giu
The alt supplies your accessories when running. I'm thinking about one to swap in quick for race days but i wouldn't run it on the street.
high torque starter should be ok for a street car. A new car will have
a little more cranking power, but they fiqure on the car may be used
for 40 degree california winters or it may be trying to crank it in kansas
at five degrees. A heavy super duper optima battary only has around
800 cranking. 400 cranking I would not go that low. who makes the 19
lb battary ??
lb battary ??
it's sold in uk at 270 usd equivaletnt by
www.demon-tweeks.co.uk
My 406 has 12.8 : 1 compression and the little battery cranks the engine without a problem.. However, if you have problems starting the car, it will run empty quicker than a regular battery but without any starting issues that require long and repeated cranking, the 11.5 lbs battery will work just as good as a regular battery.
http://www.brailleauto.com/ProductCa...=2&idproduct=1
This page has it for $179 but after shopping around, it can be found for about $159 or less...
Ebay caugh caugh....
The DMS range of Varley Red Top Race Batteries employ pure lead technology. Originally used to start fighter aircraft engines and to withstand the shock and vibration experienced in combat aircraft, these batteries have proved ideal for use in competition applications.
Small, lightweight, maintenance free and with exceptionally high discharge capability (Up to 2000 Amps instantaneous current) these batteries are flame retardant, can be fitted upright or on their side and will not leak even when damaged.
Red Top 30 Features include:
Voltage=12
Capacity=26Ah
Weight=9.0kgs
Dimensions=250x97x156mm
Terminals=M6 male
Cranking current (20?C for 5secs)=685A.
price: the equivalent 270 usd...
OR
Red Top 25 Features include:
Voltage=12
Capacity=16Ah
Weight=6.1kgs
Dimensions=182x77x168mm
Terminals=M6 female
Cranking current (20?C for 5secs)=625A.
price: the equivalent of 160 usd....
I don't know how pulse cranking amps compare to cold carnking amps but I know that it easily cranks my 12.8:1 compression engine.. That's all I'm concerned about!!
I paid $119 which isn't bad for a 20 lbs weight saving...
