carpet
Old Jan 29, 2007 | 09:38 AM
wackywitch's Avatar
wackywitch
Default carpet
I have just recarpeted my 1970 corvette. There are 9 rubber grommets 3 of which go on the firewall on each side of the front and 3 along the rear. The question I have is how do you insert these grommets ? Ihave tried every tool in my garage only managing to tear these things. Please Help.
George
Old Jan 29, 2007 | 12:35 PM
Hiteck's Avatar
Hiteck
Check either www.zipcorvette.com or www.madvet.com I'm pretty sure they carry a grommet installation tool, or something similar to that name. Anyways, it's made for installing them.
Old Jan 29, 2007 | 02:05 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
George
I tool an old large screwdriver gound the head down with my bench grinder so it was rounded, and used that
Old Jan 29, 2007 | 03:44 PM
wackywitch's Avatar
wackywitch
thanks I went onto zip corvette and found the tool.
George
Old Jan 29, 2007 | 04:35 PM
Edzred72's Avatar
Edzred72
No need to buy a tool for those. Dab a bit of grease on the tip, and use any blunt tool you have to get it started. Go into the engine compartment and you should be able to reach in with needle nose pliers and pull them out the rest of the way.
Eddie
To carpet
