Ws frame corner removal advice
Old Feb 1, 2007 | 10:33 PM
ctrain22's Avatar
ctrain22
Default Ws frame corner removal advice
I need to replace the header panel and corners of mu windshield frame. What is the best or easiest way to separate and remove the corners, leaving the uprights intact? I was thinking about a thin cutting wheel, going just underneath where the corner lays on the upright. Any suggestions from anuone would be grateful.
Old Feb 1, 2007 | 10:51 PM
SIXFOOTER's Avatar
SIXFOOTER
Weld a brace diaganolly across the upper frams and the upright to keep the posioional relationship intact. Use the cutoff wheel to crefully remove the corner from the frame, not just cutting the upright below the corner. Clean it up and weld on the mew piece. Do both corners and then the center section the same way
Old Feb 1, 2007 | 10:53 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
No need to cut anything. The corners attach with accessible screws (you may have to remove the windshield). Get the new corners and you will see where they screw into the frame. Don't cut, the corners will come right out.
Old Feb 1, 2007 | 11:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Ahh, your correct BB, I was thinking he wanted the WS frame corners, not the chrome corners, My Bad. There are 2 or 3 screws that go in from the front just above the glass and as BB says you may ned to remove the glass to get to them. There are also 2 from the backside
Old Feb 1, 2007 | 11:22 PM
BBShark's Avatar
BBShark
Now that I re-read it again, I think you may be right. OP may actually be asking about frame, not trim. Oh well, good advice either way
Old Feb 2, 2007 | 02:01 PM
ctrain22's Avatar
ctrain22
I am talking about the frame itself. I already have the ws out, molding off, etc. Ready to replace the header and corners.
Sixfooter...not much left of the header to weld to. But sounds like a good idea if I can get that done.
Old Feb 2, 2007 | 11:09 PM
spongebob46's Avatar
spongebob46
I just replaced the header and corners. The best way I found to remove the corners was to clean with a cupped wire wheel or grinder until you can see all the spot welds. Then choose a drill bit about the same size as the outside diameter of the spot weld. Drill the spot welds until you think have drilled through the thickness of the corner. Don't drill all the way through. After you have drilled the welds out use an air chisel (or hand chisel) to split the corner away from the upright. The chisel should be as thin as possible. This makes it easier to get between the corner and the upright. If you have drilled the proper depth the layers will split apart easily. If they don't, drill a little deeper, or if the depth looks OK increase the drill bit a size or two. When you get ready to weld your new parts back in, drill some 5/16" holes in the corners in locations comparable to the origional and plug weld the new corners in. If you are using a mig welder turn up the amperage and wire speed and give it a short weld in each hole. It should give you a weld that looks very much like a spot weld and will be much stronger than just welding on the ends. Hope this helps.
Old Feb 2, 2007 | 11:37 PM
RobRace10's Avatar
RobRace10
I also used an air chisel to remove the corner. It came out pretty easy at least the part I fixed. I drilled some holes in the replacement piece in order to spot weld through them.
Old Feb 3, 2007 | 12:29 PM
ctrain22's Avatar
ctrain22
Spongebob.....did you do the corners first and then the header or did you do the header corners as one unit?
Old Feb 3, 2007 | 01:20 PM
spongebob46
Corners must be removed first. Then remove the header. Header must be installed before the corners. I assume your body is sitting on the frame? If not, it is almost impossible to keep things aligned and get any accurate measurements. The replacement header I used was not even close to the same measurement as the origional. I ended up cutting the header on the drivers side and removed .25" and welded it back together. I then tack welded the header in. Attach the chrome corners (temporarily) and if yours is a t-top, use a couple of sheet metal screws and fasten the t-bar. Lay the stainless steel trim on the t-bar.Then test fit your tops. I also laid the windshield in to make sure it fit. If you are satisfied with the fit and alignment finish welding the header and install the corners.
Old Feb 3, 2007 | 02:11 PM
ctrain22's Avatar
ctrain22
This may sound stupid of me, but how do you attach the header without the corners mounted?
Old Feb 3, 2007 | 07:28 PM
spongebob46
The ends of the header should meet the top of the uprights. If you peel the old corners off, it's easy to see how the header is attached to the uprights. Also, if you look down at the top of the header you are looking at the attachment point. There are a couple of spot welds and the top edge of the end of the header is welded to the top edge of the upright.
Old Feb 3, 2007 | 09:03 PM
ctrain22's Avatar
ctrain22
Didn't know the header was attached to the uprights. So the corners are basically extra support for the frame. Makes sense. I guess when I get the corners off, I will be able to see exactly what you mean. Thank you for the info. That's what I needed to know.
To Ws frame corner removal advice
