rear main
Old Feb 3, 2007 | 08:16 AM
mooty1's Avatar
mooty1
Default rear main
what do you torq rear main seal and oil pump bolts to?
Old Feb 3, 2007 | 08:54 AM
speedreed8's Avatar
speedreed8
i recently replaced all my mains, seal and rod bearings with the engine in the car. i torqued mains to 45 ft.lbs first go round,stepping it up to 75 ft. lbs.for final, and the oil pump bolt to 55-60.ft.lbs.
rods torq. to 45 ft lbs. final. this is on a small block. all bearings were at their max. wear limit, .003", (odo. 75000 mi.) but the back of the bearings had (GM 10/81), car is a 79, so at some time , someone else has done this also, or rebuilt the engine??? cause the #'s match.
Old Feb 3, 2007 | 10:07 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I want to do the rear main on mine before driving time gets here again. I guess I should be out there doing something now.
To rear main
