I wanted to ask the opinions of those who see this stuff more often than I do. I've only built a handful of engines.
This is a new Motown Lite Aluminum SBC I just received, "race prepped".
My question is: What do you think of the cam bearings? They look like someone took 320 grit emery to them, some worse than others, front worst of all (see pics). Is this normal/acceptable? It almost looks like they did their line hone after instead of before.
Hey Jim
I tried to contact you a while ago and thought you were gone. Glad to see you back.
It does look like they were dressed a little bit. Nothing like the bearing in Kevin's block where the guy left a .030 burr and the cam didn't fit. How does the cam fit?
Block is . Cam bearings look HORRIBLE!!! I would e-mail those pictures to the place that sold you the block and ask them WTF!!!I would also have everything else checked either by yourself if you have the proper tools and knowledge or a reputable machine shop. If that is how they sent out the cam bearings check it all!!
Perhaps they are trash bearings that are in there just to protect the machined surfaces. My GMPP 383 block came in with cam bearing that looked like they were install with a hammer & screwdriver. I didn't expect cam bearings anyway so I had already purchased quality bearings and had them installed during my clearancing.
Hey Jim
Hi Gary! I've been lurkin' and readin'...trying to learn all the stuff you guys already know. I have a loooooong way to go. Never recieved any attempts to contact from you or I certainly would have responded.
Cam fits fine.....thanks to their butchering my bushings.
BTW...glad to hear you may get a check from that rip-off shop.
Thanks 63mako. I planned to email/call them Monday but I wanted your opinions before hand. I just got the block Friday afternoon. I have to buy a bore gage, mics ect. so I can blueprint this build and check their work. I will be checking all aspects. There are no good machine shops in my town.
Originally Posted by Gordonm
Those bearings look horrible.
That's what I thought
No, it's part of their "race prep" package. Sad part is I told the sales guy that I'd read a post on a forum where someone else had scratched cam bearings that World replaced and warned them I'd be on the look out for them and still got 'em. Guess that didn't work.
Thanks for taking a look guys.
By "Race prep" They must mean the bearings were run in a Baja endurance race.
Back in the day when I was a "Mopar Dude", we had problems with RB series motors (426, 440 blocks) and core shift. Every once in a while, you would get a block with misaligned cam bearing bores and have to scrape or sand the bearing bores (sometimes you had to get special sized cam bearings) to get a camshaft to fit into the block and spin freely. It looks to me like there was shift in your cam bores and someone tried to straighten out the problem, if the clearances get too big oil pressure can be low. I would have a serious talk with the seller of this engine block if you paid full price for it.
Thank you for the info. I did pay full price but I doubt they'll indicate any posibility of a core shift. Maybe I can get a machine shop to evaluate this block, I think it's beyond my capabilities.
UPDATE: World Products has offered to send me new bearings and pay a machine shop to install them. The quote I received from a machine shop was $25 to remove and install the bearings. Seems low to me but that's what they said.
I want to thank you guys again for your time and opinions.
Best regards,
Jim
There are two primary types of cam bearing installation tools.
One of them involves using a hammer. The bearings are mounted in a mandrel, and the hammer pounds the mandrel/bearings in.... about $125, the other uses a threaded rod & pulls them in... $600.
If you use the hammer tool on relatively soft cam bearings, they mushroom and distort -sometimes- making it impossible to install the cam. When this happens, the "operator" must hack away at the cam bearings to get the cam to go in. The bearing damage I see in those photo's looks exactly like they used the $125 tool with repeated insertion damage attempts until the cam slid in.
That would be my guess.
But since I wasn't there, take it with a grain of salt.
Reason: typo
