Strut rod ?
Old Feb 4, 2007 | 12:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Strut rod ?
What's different between 63-79 strut rods and the 80-82 version?
Old Feb 4, 2007 | 12:37 AM
chris73cpe's Avatar
chris73cpe
the 80-82 strut rods are mounted differently to the differential, so the ends are angled instead of at right angles like the earlier version
Old Feb 4, 2007 | 12:51 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Hmm...I'm not visualizing that well.
Old Feb 4, 2007 | 01:28 AM
chris73cpe's Avatar
chris73cpe
they changed the mounting bracket with the batwing carrier. kinda tough to see, but:
63-79
80-82
Old Feb 4, 2007 | 02:32 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ah.
Old Feb 4, 2007 | 03:05 AM
Bob3700's Avatar
Bob3700
I could be wrong but when ordering the bushing for the strut rods, there is a difference in diameter between the two.
Bob
Old Feb 4, 2007 | 04:09 AM
Twin_Turbo's Avatar
Twin_Turbo
This shows the 80-82 difference, clearly angled because camber bracket was moved backwards to the lid to case mounting flange instead of directly under the pumpkin.
Old Feb 4, 2007 | 08:53 AM
zaphodbebullbrox's Avatar
zaphodbebullbrox
Default The Angle
on the pre-79 rear ends the strut rods where (i believe) mounted a little closer to the rear end housing; problem is when the vette would squat it would cause more camber in the tires (i think camber was the right word). so in the 80-82 with the new aluminum batwing they repositioned the strut arms to cause less camber. there is a kit out there that can reposition your pre-79 strut arms to cause less camber.
please correct me if any of this in inaccurate
Old Feb 5, 2007 | 11:18 PM
tracdogg2's Avatar
tracdogg2
63-74 small ends
75-79 large ends
80-82 large angle ends
63-74 uses small bushings
75-82 uses large bushings
63-74 fit on 63-79
74-79 won't fit on 63-74 without grinding the support for clearance
80-82 fits 80-82 only
Mike
To Strut rod ?
