The original poster never posted again on this thread. I guess we will never know what is currently in the car. The profile still isn't filled out either.
Yea sure (pics?) ... you must not be referring to chevy V8 ... aside from custom made blocks AND cranks; SBC bore spacing limits max bore to about 4.2" ... BBC bore spacing limits max bore to about 4.6".
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Wow, now that's a good way to stir up sh*t, post BIG BLOCK VS SMALL BLOCK and leave
Motorhead, give me comparable heads and I'll make more power with the big block than the small block. Problem is, the 454 big block can't take advantage of significantly altered valve angles, they don't make heads of that configuration in a port size that a 454 could even begin to use.
You take your aftermarket block, bore it, stroke it and you're at 454.
I take my aftermarket block, bore and stroke it (with .025 left for another overbore, which you won't have with the SBC 454) and I'm at 565. Wanna bet which one tops the dyno in both hp and tq? This isn't even tall deck, which I think it takes to make the 454 small block. If that's the case, you can get 632 cubes in a tall deck, standard cam location big block.
Now when we start talking about the LSX stuff, I understand 522 cubes is possible. Significantly altered valve angles give this engine family a big edge over the old conventional stuff I like.
Bottom line is that you need to decide what you want to do with the car and engine and go from there. Not everyone wants or needs 750hp under the hood.
I do, but I understand there are folks that don't.
Quote:
sounds like a 2 cyl John Deere engine to me...
Yup, three unstyled A's, one styled A, two styled G's and a 28 D
Vesa, you can have all the World Products stuff you want, I'll pass, thank you. I'll go with a reputable company, plenty out there with much better reputations than World.
Are they building low quality? I do not mean component selection - they do use flat tappet cams etc cheap solutions - but the workmanship quality, is that poor reputation as well?
That, and they don't have the most stellar customer service rep. Do searches here and at www.chevelles.com and www.camaros.net. Should be enough info to help you make an educated choice.
Big block or small block, what's the difference if you have all that horse power (500+) from either one and can't get any traction.....there's plenty of Forum members that have engines in the 400rwhp and are having problems with traction now, which isn't a bad problem... I say build smart and within your budget limits, hey I'd love to have 500hp under the hood but if I can't hook up it spells one word...loser..... jmo
That block I posted is capable of withstanding 2000hp. If you put a big enough supercharger, turbo or nitrous, you can go well into the 1000hp range run on pump gas and be streetable. Whats the purpose of a big block anymore????? Power adder is where its at. If you want 2000hp or more go with a big block. But I highly doubt he plans on that. This isn't about what makes more power its that the small block can cover a lot of ground before you would have to go to a Big block. Get it.
I do believe what keeps getting lost in the translation here is: I was talking about two motors with the same volume (ci's) it doesn't take alot to realize a 565ci or a 632ci will make more horsepower than a 454 ci
Parts are cheaper for the SB and easier to find. But there is no replacement for deplacement Go BB! Becareful if you are starting from scratch with a bare block as I did and plan ahead. Those nice shinny parts will add up in no time, but they are pretty to look at.
Thanks guys,
I really enjoyed all the response to my original question. Yes, the car was an original big block, but when I purchased it, nothing was original. You have given me a lot to ponder over in the next couple of weeks. This is part of a complete frame off resto but looks like it may end up as a bad *** street rod since so much of this car was screwed up. Still like the idea of wicked power from a small block but I understand where all the big block guys are coming from. Will keep you posted on the results.
Thanks,
FEVER96
Thanks guys,
Thanks,
FEVER96
