SMALL BLOCK vs BIG BLOCK
Old Feb 4, 2007 | 04:52 PM
n.g.hayes's Avatar
n.g.hayes
Default SMALL BLOCK vs BIG BLOCK
OK Gearheads,
Need some serious feedback on how to spend my money. Ready to put power back in my totally non original 71 VET that had a 454 in it at one time. Starting with the 383, all the way up to a 502, GM crate engines of course, where do you get the loudest bang for your buck. I am also looking at power to weight ratios so anyone with previous experience, please feel free to express opinions. Plans are for a nice streetable ride that can run on pump gas and have enough vacuum to operate all the options. I love horsepower and wonder if the 383 will live up to expectations. It sure makes it nice to have a small block when bolting on headers and accessories. Suggestions and hard core facts appreciated.
FEVER96
Old Feb 4, 2007 | 05:01 PM
Little Mouse's Avatar
Little Mouse
Originally Posted by n.g.hayes
OK Gearheads,
FEVER96
The easy way to make plenty of power at street friendly rpms is
to just go big block, with aluminum heads, water pump, light starter
the weight becomes less of an issue.
Old Feb 4, 2007 | 05:06 PM
SEVNT6's Avatar
SEVNT6
No replacement for displacement........
dgruenke's Avatar
dgruenke
This forum is great in helping you spend your money. What is in the car right now? If there is a big block in the car right now, I say go with the big block. If there is a small block in the car right now, you will spend additional money on accessories, such as pulleys, brackets, etc., unless you still have those. In that case, a 383 can approach big block power.
Old Feb 4, 2007 | 06:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Small block vs. Big block, why haven't we had this debate before, I think I'll stay on the sideline this time
Seriously though, the advice above is quite good, that being, rebuild whatever you have in it right now, you can get good power out of a small block easy these days or if it's a big block already then your set
Old Feb 4, 2007 | 06:20 PM
Glensgages's Avatar
Glensgages
OK Gearheads,
Need some serious feedback on how to spend my money. Ready to put power back in my totally non original 71 VET that had a 454 in it at one time. Starting with the 383, all the way up to a 502, GM crate engines.....
ZZ502, 502 HP/567 TQ, in a mid-'70s Corvette, with headers & side-pipes, backed by a THM400 with a 10" converter, 3.90:1 gears, and 29" x 11" slicks:
idled at 700 RPM on straight pump-gas, shift at 5400 RPM, ran 12.03 @ 112+ MPH.
TRY to find a pump-gas, crate-motor that will run those numbers, at that low of an RPM (which means it'll probably last a good, long time ).
Old Feb 4, 2007 | 06:24 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
WHY NOT GO ON UP TO THE 572
Old Feb 4, 2007 | 06:28 PM
Glensgages's Avatar
Glensgages
I didn't even consider it, as I believe it is a 'tall'-block, which would mean some drastic exhaust fabrication, and few hoods may provide clearence.....
..... but I like the way you think!!!!!
Old Feb 4, 2007 | 06:48 PM
mr nasty's Avatar
mr nasty
Nothing like the sound or the sit you in the seat feel of a big block.
greg
Old Feb 4, 2007 | 07:14 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
greg
BB
Old Feb 4, 2007 | 07:52 PM
shafrs3's Avatar
shafrs3
Big block, and make it a 540. Theres no difference in weight of the engines be it a 396 or a 540. Makes tons of power and lasts a long time.
Old Feb 4, 2007 | 07:59 PM
PRNDL's Avatar
PRNDL
I have a factory bigblock, but if I was interested in bang for the buck and also wanted the car to handle, I would go with a 383. If I wanted bang and had beaucoup bucks, I'd probably build a ZL1 aluminum bigblock, something like ZL1powr has
Old Feb 4, 2007 | 08:41 PM
supervette2's Avatar
supervette2
You know what I would do is get a new DART Little M block that is a small block with the cam raised up two inches so you can fool everyone into thinking its a small block but really has the displacement of a big block. THEN put a little nitrous to it for best bang for buck
Old Feb 4, 2007 | 08:55 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
BB
Old Feb 4, 2007 | 11:26 PM
jd1a's Avatar
jd1a
I have three small blocks two with a 5.50" bore and 6.50" stroke, another with a 6.75" stroke. Two bigger blocks with a 6.125" bore and 7.0" stroke. And the big block with a 6.750" bore and 7.0" stroke, yup that's 501" They are all two cylinders, do the math. I know it doesn't belong here, but small block versus big block had been around for years. The big block is the slowest one of the bunch.
Old Feb 5, 2007 | 02:20 AM
babbah's Avatar
babbah
BBC There is no substitute!
Old Feb 5, 2007 | 07:22 AM
PNK's Avatar
PNK
408 in a standard 350block makes 500+HP with no problems and all under 6000RPM.
¨much cheaper than going BB and less weight, and less weight is unbeatable for better handling being it steering, braking or acceleration.
if money wasn't a problem i would go for a blown 427 full alu SB
"There is no replacement for displacement" is a truth with modifications, yes more CUI will give more power, but options like turbos and blowers can be your "replacement for displacement"
in the end its all about how much power you want and what you are willing to pay for it.
Personally im am a fan of the SB engines.
To SMALL BLOCK vs BIG BLOCK
Old Feb 5, 2007 | 07:44 AM
Hvymtlc5's Avatar
Hvymtlc5
New parts are cheaper for SB. Used parts are easier to find. If money is not a concern.....go BB.
Old Feb 5, 2007 | 08:28 AM
Vesa's Avatar
Vesa
World Products all aluminium 540 is the way to go!!!
Old Feb 5, 2007 | 09:45 AM
L88Plus's Avatar
L88Plus
Vesa, you can have all the World Products stuff you want, I'll pass, thank you. I'll go with a reputable company, plenty out there with much better reputations than World.
