Ported Vacuum vs Manifold Vacuum
Old Feb 6, 2007 | 11:40 AM
Ed Blue 03's Avatar
Ed Blue 03
Default Ported Vacuum vs Manifold Vacuum
Getting ready to set the timing on my rebuilt 73 – 350. Have always used Ported Vacuum for the distributor advance, but based on what I read on this forum, currently have the distributor connected to Manifold Vacuum. This car is a weekend cruiser and occasional drag strip car, so fuel economy is not my number one priority, performance is. Should I stay with the Manifold Vacuum?
Old Feb 6, 2007 | 11:45 AM
Durango_Boy's Avatar
Durango_Boy
I would keep it that way.
Old Feb 6, 2007 | 11:46 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Absolutely,..she'll idle better, run cooler, and you'll have better off-idle performance. Some think they're on man-vacuum but not. Use your vacuum guage to make sure.
Old Feb 6, 2007 | 01:31 PM
stingr69's Avatar
stingr69
It makes no difference in "performance" either way. Manifold, ported, or none at all will all have the same HP and track numbers. Vacuum advance has no downside, only upside.
Manifold is better when just driving/idling around town but you need to select a different vacuum can if you want it to work right. If you do not want to spend the effort and $10 for a new canister then ported is what you need. You can just hook it up to what ever you have and go.
Aren't you glad I did not type a long technical explanation. It has been done here quite a few times so I will save you from having to read all those old techy detailed threads.
-Mark.
Old Feb 6, 2007 | 01:33 PM
lars's Avatar
lars
Use whichever sourcve produces the best quality idle - not neccessarily fastest idle. In most cases, this will be manifold vacuum, but it depends on how big your cam is and how much initial advance you're running. Just give the engine what it wants for best operation. If you have to pass emissions, use ported.
To Ported Vacuum vs Manifold Vacuum
