Dexcool Bad?
Old Feb 6, 2007 | 01:55 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Default Dexcool Bad?
Just saw in the green/yellow prestone thread
dexcool is not right for the C3?
I hope this is false, I am using it.
Old Feb 6, 2007 | 02:07 PM
rosslato's Avatar
rosslato
Dexcool if u have an aluminum radiator
Old Feb 6, 2007 | 02:09 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Dexcool isn't all bad. However, the green and the orange can NEVER mix. They will crystalize if they do. To switch from one to the other, they cooling system must be flushed and cleaned or you are looking for long term trouble.
However, it has been a major cause of headaches in my '96 Chevy p/u. The dexcool was known to degrade the gaskets it is in contact with. I've been told that the gasket material has been adjusted accordingly, but I don't believe it. I've changed my water pump gaskets and intake manifold gaskets twice each in 145k miles. Now, the more important question, why am I still using it? I have no idea. Guess I never thought I'd still own the truck after 9 years.
I've also read that flushing and refilling the system will reduce the effect on gaskets. Still haven't seen much proof of that. Of course, everyone has a different opinion and experience with the stuff.
Old Feb 6, 2007 | 03:02 PM
Stewart's74's Avatar
Stewart's74
I had a 98 blazer that only was serviced by the dealership. By 2001 the cooling system was so clogged by sediment that the entire system was replaced by GM. Many claim that the dexcool was the problem. It wasnt admitted by the dealership however, when I began litigations against GM under Ohio Lemon Law, they settled out of court almost immediately.
Old Feb 6, 2007 | 03:03 PM
Kalway's Avatar
Kalway
Dexcool =
Just use the green stuff and change it every other year.
Old Feb 6, 2007 | 03:27 PM
mrvette's Avatar
mrvette
Originally Posted by Kalway
Dexcool =
PERZACTLY, the green ethelyn glycol has worked for decades in aluminum, iron.copper, brass, rubber, ***, whatever....
why change??? NO GOOD REASON....
must be an EPA thing.....much adoo/nonsense over nothing....
something about 1 part per brazillion in the rivers.....meaningless....
Old Feb 6, 2007 | 06:54 PM
chris75stingray's Avatar
chris75stingray
they didn't even have dexcool when they came out with aluminum radiators. so why change to a different coolant now?
Old Feb 6, 2007 | 07:10 PM
Durango_Boy's Avatar
Durango_Boy
I say if you WANT to trash your radiator, heater core, freeze plugs, and gaskets...then by all means use Dex. As a bonus, it'll clog everything up good and gooey like. Go for it.
If you want a clean system, that works as it should, use green, or Preston's new Yellow.
Old Feb 6, 2007 | 07:29 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
At the time I switched the 5 year life appealed to me
I have run green for the first 20 years and the
2 year change out came faster and faster (age )
I thought hey 5 years Kool.
The Internet has made me smile, taught me stuff, and
made worry about OIL, Filters, Gas and now coolant.
Ain't it great ?
thanks for your experiences and thoughts
Old Feb 6, 2007 | 07:46 PM
GaryS's Avatar
GaryS
Well, not exactly! The problem with traditional glycol based antifreeze is that the "white stuff" precipitates out with age. This has ALWAYS been a problem (at least as far back as I can remember - 30+ years), but one that can be solved by frequent flushing of the cooling system. There was a tecnical discussion on the NCRS DB about this problem as well as the issue with Dexcool. As I remember, the best solution is to use Zerex G-05 which does not have the same issue with this precipitation. It still has a lifetime, 5 years as I recall. I personally use Zerex in all of my cars, including my 72.
Old Feb 6, 2007 | 07:49 PM
Durango_Boy
Great to know. Another good option.
Old Feb 6, 2007 | 07:51 PM
ShaneLU97's Avatar
ShaneLU97
Ain't it great ?
Now I am paranoid as well! I was about to replace some hoses and therefore have to refill my coolling system with 50/50 dexcool and distilled water but now I am thinking that is a BAD idea. So how extensively would I have to flush my system (and how) to switch cooants?
Shane
Old Feb 6, 2007 | 08:03 PM
Durango_Boy
Shane
Completely.
Completely drain the system by draining the rad and pulling the water jacket plugs in the sides of the block. Get all the coolant out and dispose of it.
The quick and easy way to flush is a water hose. Remove the upper and lower radiator hoses, and start by flushing garden hose water into the upper rad hose. Stuff a rag in around it so you have good pressure and let it go until the fluid coming out the bottom rad hose is clear. Do the same for the radiator.
Then button it all up, and fill with a 50/50 mixture of the new fluid of your choice.
Old Feb 6, 2007 | 10:08 PM
JPhil's Avatar
JPhil
If I may interject once again about home-flushing the coolant:
It's a real biatch to disconnect the bottom hose, but why bother anyway? Use 3/8" or larger piece of rubber oil line at least 6' long and siphon the radiator.
Drain the block, siphon the rad, fill it back up with water, run the engine till it starts circulating, and then just siphon and top off continuously while the engine is running and circulating, until the water is clear in the bucket. Do this till you're comfortable the system is flushed.
Then, in my opinion, drain the block and rad again, and fill with Zerex GO5 and distilled water.
And, again, to get the siphon going, wrap rag around the hose at the filler neck and BLOW through it to pressure up the rad to start the siphon.
John
Old Feb 6, 2007 | 10:12 PM
Durango_Boy
John
There is a great mental image associated with this tip...which I love, and I would really like to see Photovette1 doing a how too video with his models, and siphoning out the radiator fluid. I wan to see closeups of her blowing first to pressurize the radiator.
Old Feb 6, 2007 | 10:21 PM
dgruenke's Avatar
dgruenke
I have known people that have flushed the Dex out of their new cars to put the green back in.
Old Feb 6, 2007 | 10:32 PM
ShaneLU97's Avatar
ShaneLU97
Thanks for the info guys...Looks like the next chance I have to pull the Vette out of the garage I am going to be flushing the system as well.
To Dexcool Bad?
Old Feb 6, 2007 | 11:01 PM
Durango_Boy
Good luck. While you're in there, make sure your radiator is sealed well, and that your fan clutch is good.
Old Feb 6, 2007 | 11:15 PM
SEVNT6's Avatar
SEVNT6
Prestone only for 30 years. Radiator looks great inside....
Old Feb 6, 2007 | 11:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I looked at my coolant container closer...........
Havoline Ext Life 5 year (orange)
Dexcool GM approved.
Is this Dexcool? Or Did I escape...............
