Dexcool Bad?
This is not a smart idea at all. Your water pump will probably go first. Then your hoses will start cracking and leaking. I would suggest using even a small amount of green or yellow in there.
I agree that distilled is okay if you are not using a 1 or 2 year fluid. If you flush every year or so regular house water will be fine.
I actually use 1 part green, 1 part 40 Below, and 3 parts water. Lowered my temps by 30 degrees.
http://www.ecklers.com/product.asp?p...dept%5Fid=1249
IMO, distilled water is a must with an aluminum radiator. In fact, our new warranty requires the owner to use 50% distilled water and 50% premuim coolant. I don't care what coolant you use, green, organge, or blue. With aluminum radiators the water is more important than the coolant. Most people recognize the minerals in well water, sodium in softened water, but forget that tap water has many minerial too. Calcium and floride have also been added to many public water systems. I have had people ruin a brand new radiator in only six months with calcium heavy city water and 50% coolant. Dexcool got a bad rap with all the early horror stories but I think those bugs were worked out a long time ago. GM and many other stick my the formula and the jello stories are most likely due to operator error. I don't promote Dexcool or condem it. The only advantage I see to Dexcool is the long life protection the product offers. Now here is where 99% of the public do not understand about Dexcool is that once a system has had green in it, you can never get the five year protection from dexcool. You can flush the hell out of it and get every drop out but once it was filled with green, you have a two year system, period. So, if you used green already and the only advantage to Dexcool is the extended life, which you wouldn't get, then it's wasted money. If you installed a new engine, new hoses, surge tank, and a new radiator, then Dexcool might be a good idea, but only then. Distilled water only cost a couple of dollars and if you have an aluminum radiator it is money well spent. All of the pre-mixed coolant sold today are made with distilled water, so you don't even had to go to another store to get it. I would change my coolant every two years even if I had a five year system. It's just cheap insurance. Straight water is not a good idea because coolant isn't just for freeze protection, it has an inhibitor package that protect all your internal components from rust and corosion, and lubricants for seals and bearing. People that swear by the additives are usually seeing the results of high water content systems and it's the water that cooling better, not the $8 bottle of additive. If a secret additive that would lower the coolant temps 30 degrees really existed, prestone would simple put it into their product. Oh, I know some will swear by this stuff and if you believe then I'm ok with that.
When I built my V8 S15 Jimmy I stayed with the green stuff because that is what had been used before and I didn't change the radiator or heater core.
I do have a series of how to videos in the works, but we're waiting until warmer weather.
My guess is that Mr. DeWitt has the equipment, knowlege, and knowhow to be able to prove whether or not someone was using a 50/50 mix or not, or did something else to void his warrenty and ruin his product.
I'm sure Mr. DeWitt will reply later... so I don't know why I'm answering what I really don't know. I'm just sure their are ways for him to tell.
Here are a couple of factual links.
http://www.wixfilters.com/productinf...ntfilters.html
http://www.polarislabs1.com/coolant-analysis.htm
oh, and everywhere I saw a white pile of calcium build up, it would poke through with a punch creating another leak.
