L-88 air cleaner ?
Old Feb 7, 2007 | 01:55 AM
6t9427's Avatar
6t9427
Default L-88 air cleaner ?
I am switching from my stock big block hood to an L-88 hood. Does the L-88 air cleaner assembly use the same base for the carburetor as the stock open element setup for 4 barrel carb.
Second question is stock open element air cleaner base the same for Holley and Quadrajet carbs?
(might be asking same question 2 different ways.)
Old Feb 7, 2007 | 03:44 AM
Vesa's Avatar
Vesa
Do not know the stock but L-88 is drop base...
Old Feb 7, 2007 | 07:34 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
The L-88 base was used on LT-1's, L-88's and the L-46 engines amoung others. Was also used on some passenger cars....Impalas, I think.
Don't know about quadrajets but the base doesn't work with Edelbrock carbs.
Old Feb 7, 2007 | 04:22 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
the base on my 71 is the same as the L-88 base.
Old Feb 9, 2007 | 02:53 PM
70/LS/6's Avatar
70/LS/6
Base will work & quad will work.
To L-88 air cleaner ?
