Steering Column Disassembly (pics)
Old Feb 9, 2007 | 09:01 AM
11Jake's Avatar
11Jake
Default Steering Column Disassembly (pics)
I have a 1980 Corvette w/ tilt and telescope steering column.
I want to repaint the steering column covers/shrouds and I want to regrease all the bearings in the column. I have most of the column apart but I am stuck. It is the assembly with the shaft Knuckle that I can't seem to figure out how to disassembly. I did a search on the forum and looked at all Jim Shea's papers; which are very helpful. Do I need to take the steering column out of the car to disassembly the lower part of the column? Sorry for the fussy pics, I have a crappy digital camera.
Old Feb 9, 2007 | 12:28 PM
Duke94's Avatar
Duke94
PM me your email address. I have some pictures I took a few years ago that my help you.
Old Feb 9, 2007 | 03:36 PM
kortensi's Avatar
kortensi
Hey Jake,
I have the rebuild of a 77 column documented here:
http://forums.corvetteforum.com/show...107000&page=18
The next thing that you need to do is remove the piviot pins on both sides of the column. The way that I did it is to screw in a small bolt into the piviot pin and pull it out with a hammer ( just like you would a nail stuck in a board). Be careful though because someone else tried it and cracked the housing.
Hope it helps.
KO
To Steering Column Disassembly (pics)
