Rear end differencies???
Old Feb 7, 2007 | 03:48 AM
Vesa's Avatar
Vesa
Default Rear end differencies???
Most of the parts store sell differential assemblies and say they fit 65-79. What is the diffrence compared to 63-64 rear ends? On the other hand if you look individual parts (seals, bearings etc) most of the are for 63-79...
So do you know what is the truth can -64 rear end be used in -65 and never C3/C3 and still what is the exact difference...?
Old Feb 7, 2007 | 04:36 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
63-64 had a different carrier unit inside the case, IIRC.
Old Feb 7, 2007 | 06:11 AM
Vesa's Avatar
Vesa
Can you buy a 65-79 carrier unit (like brand new Eaton 3-series) and drop it inside a 63-64 case just like that using the existing 63-64 ring&pinion?
How is the 63-64 carrier different? Weaker? Different type clutches&springs..?
Old Feb 7, 2007 | 11:03 AM
sly vette's Avatar
sly vette
Sorry to interrupt.. but what doe's IIRC mean??
Old Feb 7, 2007 | 11:09 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If
I
Remember
Correctly
Old Feb 7, 2007 | 11:11 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm running on memory here (and I know it's been discussed here, an archives search should reveal the info), but there was something about the carrier that made it prone to cracking.
Old Feb 7, 2007 | 11:14 AM
Vesa's Avatar
Vesa
OK, sounds like I should stay away from the -64 unit that is offred now for me as part of the whole payment...
Old Feb 7, 2007 | 12:44 PM
GTR1999's Avatar
GTR1999
The 63-64 used a diff case,which was junk and blew up. Most of them are probably changed to Eaton by now. The 65-70 used Eatons and the case was better but not as good as the Eaton case from 71-79. The clutches used in the 65-70 are better but the spiders are junk. The Clutches used in the 71-79 are junk and the spiders are much better.
You can use an Eaton in a 63-64 but who ever is going to set it up better know the kits sold do not have the correct case shims in them for the 63-64- that's why they are not advertised. You need to buy a separate $75 shim kit and use a surface grinder to dial it in.
New Eaton loaded posi are available for about $500 and have great cases, can't say I like anything else about them. I would buy a new bare case and build it. I have one coming in next week to do this to in fact.
To Rear end differencies???
