I have heard through the grape vine you can put c4 blower motor and cage in a c3 for better blow please help
Take out the old fan, and buy a new C4 fan. I think they are like $15. Find a couple .5" cutting boards from Harbor Freight, and use the template below to make your cutout. Glue the two together so you have a 1" spacer. Drill holes and pin location, and mount the fan. The fans are the same size except the new fan's blades are more, and higher pitch. For even better results...install a relay for the new fan, powered by the alt's BAT terminal, and use the original fan power wire to trigger the relay.
I'm still working on cutting mine out. My jig saw moves to fast it melts the plastic and the blade jams up. I will get it finished when I get a variable speed jig saw.
i used a cap for a bot belly stove pipe. a end cap, menards for 5 bucks, traced the fan mount on the end amd cut out with tin snips,used a vaccume line slit lengthwise for a gasket-----------------------------------------------
I did mine--I used a 6" pvc coupler and sliced a 1" section from it. You get about 30-50% more air. I tried to put one from a Nissan in (those a/c's blow!) but it spun in the wrong direction.
Check your local salvage yard. I was out two days ago, and I swear, every GM car that I came across from the mid 60's through late 80's use the same blower motor assembly. The larger land yatchs, Olds. Cadillacs etc use a slightly large blower wheel/fan but designed to fit the same blower motor and OD. These can be had for a couple of bucks and will improve airflow, best of all buy the whole thing and just plug and play, same mounting and electrical hook-up as what you have.
Someone sectioned their case and 'glassed it back together so that the C4 fan fit naturally. It had the added benefit of unshrouding the A/C evaporator.
if you use the cap for a stove pipe,its 2'' long,so all you have to do is trim 1/2 of a inch off the length,because the new squirrell cage is 1-1/2''longer,,,,and on the face of the cap trace out the form of the blower housing and cut it out, thats it,,,of corse you will need longer screws,,once you paint it black you can barely notice that it was extended,like i said i used a vaccume line slit lengthwise for a gasket,,,total cost without the blowermotor was 5 bucks for this mod,,,i bought the blower motor and deeper squirrell cage from carquest it was a bravo blower motor,,not only is the squirrell cage deeper but the fins on it are angeled more to improve the airflo--i still had a minor leak so i used dum-dum where the 2 pieces join-------------------------------------
fred68 thanks a friend is giving me one from an older monte he striped out I will measure it this week end but next 2 weeks are Datonna no work till after race week
Has anyone found where you can get the C 4 fan without buying the fan-motor assembly?
larry
71 a/c
Just pull a C4 fan from a salvage yard and take the blades. I don't know why you would want to do that though...the motors are not that much different...it's the blades that make the big difference.
fred68 could you switch wires to make fan turn the other way that is how to change directions on cooling fans mounted in front or behind the radiator
