heat shield
[IMG]
[/IMG]
Besides, you don't need to wrap ceramic headers or the pipes on your '81. Ceramic headers keep my engine compartment a LOT cooler then my previous block hugger headers. The cross-member mod I made this summer works GREAT with no floor pan heat problem.
Here are a few pics that show what worked for my '80. I can give you more details if you want them. (I previously posted the steps I took too.)
http://store.summitracing.com/partde...5&autoview=sku
I drew a full-width circle on a piece of 1x4 pine (3 1/2" width) and cut off one end to make a rigid pattern for the cutout.
I used the pine board and a can of spray primer to mark each side of the cross member. I just eyed the spot I thought would leave an adequate gap between pipe and floor pan yet clear the trans mount.
I measured the distance from a fixed "ground" reference (the cross-ramp platform on my lift in my case) to make sure the edges of the front and rear cuts were level.
I used masking tape from the bottom of the front painted semicircle rearward to make sure the cutout was going to be straight back - parallel to the center line.
Once I had the cutout marked with primer, I used a small air-power cutoff wheel to cut the cross member and smoothed the edges.
I treated all the surface rust inside the cross member while I had an access hole. The whole process took about an hour.
The exhaust guy took a piece of 3 1/2" diameter exhaust pipe, sliced it down the middle, held it in the cutout to trace the cross member onto the pipe section, cut the pipe to fit the cutout, welded the pipe section into the cross member, and primed and painted it with semi-gloss high temp (1200 deg) paint.
The exhaust guy did an excellent job of tucking the pipe into the cutout. The driver's side pipe is at the same height as the pass side pipe. He said that the pipes were easy to bend for the rest of the job because the angle of the bends from the cross member back were pretty low.
I hope your true dual project goes as well as mine did. You're going to love the sound and notice a nice performance improvement on your butt-o-meter.
