Rear Coil overs
Old Feb 11, 2007 | 03:17 PM
  #41
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by turtlevette
another concern of mine is that you can't find spring rates over 400 pounds for these things.
I run 450 pound rear springs 10 inches long. They are no problem to get.
I bought a set of 250,300,350, 400 and 450 for testing and settled on the 450 in the back and 400 in the front.
I bought all sets in 12 inch lengths but later had to get another set at 450 pounds in the 10 inch length for the back. The 12 inch didn't allow me to lower the car enogh.
I set my ride height in the back with a level on the 1/2 shafts.
Old Feb 11, 2007 | 05:26 PM
  #42
sly vette's Avatar
sly vette
Originally Posted by sly vette
I know that a few have done this mod, and since I will be pulling the body off I thought this would be a good time to approach this project. I did a search but all I came up with was info on the front. Can any
one point me in the right direction for the mounts I will need for the rears??
Also has any one ever made their own control arms for the front???
Thanks in advance,
Old Feb 11, 2007 | 05:40 PM
  #43
henny496's Avatar
henny496
Hello Norval
I sent you an e-mail about the possibility if you want to sell some of your springs
My coil overs are behind the rear end, straight up and down
take care
Tom
hope to see you this coming summer at a cruise night
Old Feb 11, 2007 | 05:45 PM
  #44
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by Twin_Turbo
no springs over 400? I have 450s right here
ok hard to find springs over 450. You take things so literal.
To get a equivalent of a 420 fiberglass leaf you'll need something close to 600#.
Old Feb 11, 2007 | 05:58 PM
  #45
norvalwilhelm
Here are a few pictures of my rear coilover mounts. They are welded to the trailing arm. They also place the shock in a straight up and down position. I used 1/8th material, boxed it in and welded a threaded mounting boss to the bottom'
Everything falls inside the 18 inch rim so no chance of bottoming on the ground. they are also no lower then the strut rod mounts.
Old Feb 11, 2007 | 05:59 PM
  #46
redvetracr's Avatar
redvetracr
Not if you want your car to "ride like a Cadillac"......who was it that said that???
...redvetracr
Old Feb 11, 2007 | 06:00 PM
  #47
norvalwilhelm
That is not yellow overspray on my 1/2 shafts. I purposely spray like that so when I remove and replace anything it goes back on exactly as it came off. Alot of removable parts are oversprayed over the black powdercoating so I get it back in the same orientation as it came off.
Old Feb 11, 2007 | 06:01 PM
  #48
Twin_Turbo's Avatar
Twin_Turbo
Why would you need something close to 600? If the stuff mounts in the same rough location the spring rates required are very similar as the relationship to the wheelrate is similar.
As for literal...if you want 1150# springs, hypercoils have them.
Old Feb 11, 2007 | 06:05 PM
  #49
norvalwilhelm
For an upper mount I put it in the same location as the stock mount. I cut the stock mount off, plated the frame both on the bottom and side and then welded a solid billet mount in the same location.
I ran a 140 pound leaf spring that mounts to the back of the trailing arm. With the coilover and the spring mounting in FRONT of the axle you require alot more spring pressure. I tried everything and kept bottoming the suspension. The 450 pound spring ride about like 140 pound rear spring
Old Feb 11, 2007 | 06:15 PM
  #50
68 NJConv 454's Avatar
68 NJConv 454
Norval, is that your emergency brake caliper? was it you who was thinking of mounting an emergency brake & small emergency brake rotor on the front of the differential? or was that TT?
What calipers and rotors are you running? In the last pic the calipers look stock.
Your coilovers didn't hit the battery & storage boxes?
Old Feb 11, 2007 | 06:19 PM
  #51
Twin_Turbo's Avatar
Twin_Turbo
that's me..I'm going to do it like that.
Old Feb 11, 2007 | 06:22 PM
  #52
turtlevette
thanks Norval, The trailing arm is a lever and has much more mechanical advantage at the convenient coilover mounting position in front of the axle. The leaf acts upon the very end of the arm behind the axle.
TT is losing his edge, i think DB caused him to have a small stroke.
Old Feb 11, 2007 | 06:25 PM
  #53
norvalwilhelm
I mounted a light weight caliper with 2 live pistons to each rear rotor. It operates like a normal emergency brake but actually works quite well. The car actually slows down quickly when you pull the parking brake. I am running stock rear calipers and consider them more then adequate, the rotors are just drilled stock original units. They are 3 pounds per caliper underweight and came with the car back in 1975
No my coilovers do NOT touch the battery boxes. No paint on the boxes has ever been scratch. They clear under the worst conditions by about 1/4 inch
Old Feb 11, 2007 | 06:29 PM
  #54
norvalwilhelm
My son puts the parts together to make a hydraulic emergency brake. It consists of 2 light weight rotors with 2 live pistons, 4 brake pads with free replacements in the future, 2 master cylinders, one for each rotor, 2 flex lines and an assortment of banjo bolts and washers, he just grabs a handfull and throws them in the box.
You have to make aluminum spacer to spread the caliper for our larger rotors, a mount for the trailing arm , a spur for the parking brake, mount the master cylinder and slightly space the back of the brake cover up at the back for clearance.
It actually comes together quit nicely and works. Who can say that about the stock setup???
Old Feb 11, 2007 | 06:31 PM
  #55
Twin_Turbo's Avatar
Twin_Turbo
The mount position wasn't specified, and I said it depended on location. Some people here have coil overs mounted BEHIND the bearing hub which would give a very similar spring rate as a stock type leaf.
You just said you need a 600# spring to do the same as a 420# fiberglass one. There was no mentioning of spring location so in that respect alone the whole statement was moot. Now, i know you're going to say I'm being **** and what not..
Old Feb 11, 2007 | 06:34 PM
  #56
Twin_Turbo's Avatar
Twin_Turbo
BTW, the chance of you causing me a stroke is infinitely more likely
Old Feb 11, 2007 | 06:35 PM
  #57
sly vette's Avatar
sly vette
So you are using the coil overs and a 140 lb single leaf "booster"?
And there is no way to mount the springs behind the rear wheels,huh?
To Rear Coil overs
Old Feb 11, 2007 | 06:48 PM
  #58
norvalwilhelm
No booster, no leaf spring. I just said the leaf spring that mounts to the back of the trailing arm was 140 pound per inch spring. With the coilovers mounted in front of the axle I required a 450 pound spring because of the mechanical effect.
I just want to save someone money and not buy all the sets i did for testing. Springs here run $172 per set and I bought 6 sets or about $1000 worth just to find 2 sets that I could use.
Old Feb 11, 2007 | 07:01 PM
  #59
sly vette's Avatar
sly vette
I can see from the amount of mods on your car that you have much more ability than I do at this time. I also believe you probably learned these skills by just jumping in and doing it, and I guess that is what I will have to do also. I have a lot of questions but the channels of communication become muddy here from time to time.
SO I think I will look into someway, if poss, to mount the shock and spring to the rear of the axle.
Thank you for your time and patience again!
Old Feb 11, 2007 | 07:23 PM
  #60
lvrpool32's Avatar
lvrpool32
What length coil overs are we talking about here? I take it someone could use another brand than Koni, I would like to use QA1's as thats what i have up front.
Nick
