Rear Coil overs
Old Feb 8, 2007 | 11:55 AM
sly vette's Avatar
sly vette
Default Rear Coil overs
I know that a few have done this mod, and since I will be pulling the body off I thought this would be a good time to approach this project. I did a search but all I came up with was info on the front. Can any
one point me in the right direction for the mounts I will need for the rears??
Also has any one ever made their own control arms for the front???
Thanks in advance,
Old Feb 8, 2007 | 12:39 PM
Godfathers Ghost's Avatar
Godfathers Ghost
Thanks in advance,
Check with QA1 motorsports. they have some of the best coil-overs out there and although I dont think they have a set specifcaly for C3's, I spoke with them just last week about customs and they said all they need to know is the type of ends you need (mounts), extended and compressed lengths, and the aprox. corner weights. But you are gonna have to check clearance for the spring, its kinda tight with the control arm down low and the battery box up high. I'm not sure about it, I converted to a fourth-gen 5 link with a VB&P dual mount spring and bilsteins. Let me know how it looks, you got me curious now.
Good luck
Old Feb 8, 2007 | 12:48 PM
sly vette's Avatar
sly vette
Some one sent me a pic that showed roughly how they mounted the rears. There was a tall reinforced bracket coming up from the rear of the TAs as the lower shock mount with just ears, I believe for the top. I didn't get into clearance issues. Now I can't remember who it was. I hope they will see this and chime in!
Do you know any one who has made their own control arms for the front???
Trying to save as much cash on this mod as poss.
Old Feb 8, 2007 | 01:08 PM
Godfathers Ghost
Oh yeah, about the control arms. There's too many good after makets available to worry about it...VB&P, Speed Direct's aluminum uppers, Jim Meyer racing, there's more but I can't think of em all. If you really want to make them your self use the factory arms to get dimentions, make a plate to bolt the ball joint to, weld it to tubing with threaded ends for some rod ends. You will probably have to use high misalignment rod ends. Add some extra pieces to the lowers for spring/shock mounts, a bump stop, and your bassically done. Just make them STRONG, your life depends on it. You can get most every thing you need from chassisshop.com
Old Feb 8, 2007 | 01:55 PM
zaphodbebullbrox's Avatar
zaphodbebullbrox
Default rear coil overs
check out speed direct
http://www.speeddirect.com/index.aspx?nodeID=132
Old Feb 8, 2007 | 01:59 PM
sly vette's Avatar
sly vette
Thank you but I am familiar with Speed Direct...And their prices and that is my prob...I can't afford the parts, gotta' try to make 'em.
Thanks for the heads up though!!
Old Feb 8, 2007 | 09:16 PM
Bob3700's Avatar
Bob3700
Default Front Arms
SLY,
What is your goal for those front a-arms? Lighter wt, better front end geometry or just cool looks?
You can cut the senter out of a stock arm to make it lighter.
You could look at the conversions that adapt later model aluminum arms to a C3.
I had a set on my old GT-1 car that were modified for lighter wt. and to help clearance for front coil overs. They cut the center out of the arm, welded in tubular front and rear pieces, and manufactured the frame attach bushing area. They were cheap, light, and ugly. But they worked.
Bob
Old Feb 8, 2007 | 09:29 PM
norvalwilhelm's Avatar
norvalwilhelm
I'm the guy with the rear coilovers and I posted the picture.
Old Feb 8, 2007 | 09:30 PM
norvalwilhelm
Old Feb 8, 2007 | 09:48 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Hey Norval, did you put that system together or is it available?
Sly, I hope you at least take a good look at whats available aftermarket, you can pick some good stuff up cheap. I think most on here have learned hard lessons about fabricateing. If you are truely good at it, bless you, few of us really are. If not key components and assemblies that have some experience and engineering behind them save headaches and money.
Old Feb 8, 2007 | 10:03 PM
Ironcross's Avatar
Ironcross
We do it all from stock including control arms and complete frames. Sideways mounted coil overs dont excite me. Put a 9 in. Ford in it with coil overs and a 4 link. If you can make control arms, a narrowed Ford rear wouldn`t be a problem.
Old Feb 8, 2007 | 10:21 PM
68 NJConv 454's Avatar
68 NJConv 454
Norval and TT both designed and built their custom rear coilover setups. Both are different in design and both members are gifted with knowledge and a welder.
Norval used a trailing arm, TT built his own rear control arm A frames.
Both very
What is that speeddirect rear system going for? I can't imagine its under 2k. They are rediculous with their prices. Cool design though, kudos to them for thinking outside the box.
I knew it was is the design phase, didn't know it was released to the public. Wonder how it performed in their test car.
Old Feb 9, 2007 | 09:19 AM
sly vette's Avatar
sly vette
Hi Norval, Welcome back I hear you were on vacation. Or do you say Holiday in Canada?
Anyway...How much work am I looking at to do this mod.
The rears are what I am going to focus on at this time.
Did you just mount the shock on the lower factory mount and then fab some ears for the top?
Do you mount the shock at full extension?
Thanks for any help, and I haven't been able to do much on the trans swap due to the cold,but I'm ready to go at any time. Bernie has been helping alot!!!
Old Feb 9, 2007 | 09:30 AM
norvalwilhelm
The shock must be the 5 inch travel shock, the 7 inch will not fit. This 5 inches gives you 7 inches of wheel travel.
The stock top mount is in the right location but I cut it off and made a much beefier one but welded it right back in the stock location.
I then made bottom mounts, I could take good pictures of it now with the car on blocks and the wheels off.
I welded this mount to the trailing arm infront of the 1/2 shafts. I used nothing from the stock lower shock mount.
If you need pictures I can do that this weekend.
I then used 450 pound springs which are still soft in this location
Old Feb 9, 2007 | 11:55 AM
sly vette's Avatar
sly vette
Pic are always a welcome addition. And any measurements that you may remember.
Old Feb 9, 2007 | 12:57 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Feb 9, 2007 | 01:24 PM
Twin_Turbo's Avatar
Twin_Turbo
...ze germanz alzo did it like zis
To Rear Coil overs
Old Feb 9, 2007 | 01:47 PM
big_G's Avatar
big_G
TT, you have my attention....any rear view pics. to see tire/ground clearance issues?
Old Feb 9, 2007 | 02:55 PM
68 NJConv 454
Me too!
There must be modifications to the battery and storage boxes. Which is a small price to pay for rear coilovers.
Old Feb 9, 2007 | 03:27 PM
Twin_Turbo's Avatar
Twin_Turbo
no mods 1st pic shows coil over mounted to stock mount. Ground clearance is just like Norvals setup.
