Draining the block.
Old Feb 8, 2007 | 08:35 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by JPhil
a) if you run hard pipe, the resonant vibration will crack it eventually, and lots of mounting brackets won't cure it.
I hadn't decided on material, or if there would be a tube at all. I just want a valve that when released will pour a controlled stream of liquid right where I want it instead of dripping all over the place. I like things clean.
d) the small diameter of the tubing is easily plugged by gunk which settles to the bottom of your sump, plugging the line.
I would never run a tube off of my oil pan. A drain valve is all I would want there.
e) if you reduce the need to get under the car periodically, you reduce the frequency of general inspection for other potential problems.
I like getting under my car and that won't change...it's the mess I'm focusing on, and the ease of draining the fluids.
Old Feb 8, 2007 | 08:37 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Originally Posted by Durango_boy
I believe you were being serious...I just didn't even quite understand what you meant.
The water gets pumped out from the upper radiator hose why you are filling up the radiator and flushing out the old stuff.
Old Feb 8, 2007 | 08:45 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I think a good "back flush" will remove more harmfull
debri than a petcock.
The petcocks I have on my boat have "small" openings.
A tee in the heater hose is my answer.
What was the question?
Old Feb 9, 2007 | 09:10 AM
Tom454's Avatar
Tom454
Since I actually did the "operation" (albeit on a Ford), I can add some info here...
I have done this, on other vehicles and machinery in the past. The problems are with your piping connecting the sump (or whatever) to the remote valve:
===> If the tubes are short enough and rigid enough, this will not be a problem. My Ford 390 was bored 60, re-cammed, and I had the 62 T'Bird BB TriPower on it.... positraction 9" diff... it was a fun car and in spite of its weight, moved pretty good... I beat on it regularly.
I had no problems with the fittings & tubes. You just have to engineer it properly. The pipe connection (threads) at the block are the main issue. You have to deal with that with some degree of intelligence.
b) with rubber tubing, the rubber degrades or is damaged by heat, chafing, other chemicals, or can come loose and be torn.
===> Don't use rubber.... use metal.
c) they are both subject to being snagged or inadvertantly damaged in the course of other work or daily hazards.
===> Yes... this was one of the issues I had. Be careful working around it, or expect to repair it on the fly.
===> Yes... I solved this simply by blowing compressed air backwards through the petcock when open.
===> It doesn't reduce the need to get under the car... it only aids in draining the block below head level so you can work on the upper end with little or no water intrusion. That's why I did it originally.
I do have draincocks on my block, and they come in handy when I need them, which is not very often. I will put a drain plug on my differential when I rebuild it. But anymore, I prefer the PIA of getting under the car when doing this kind of stuff so I can periodically inspect everything
===> Typical Gear Head
.....In my opinion, while it sounds like a good idea, adding things like this only adds more areas of potential trouble.
===> Potential... agreed. In reality, that wasn't my experience.... my block drains worked great and saved me a lot of cleanup time & a lot of mess.
John
If you're going to race... this is probably a risky proposition. You don't want that "potential" to rear it's ugly head. But for cruisers and trailer queens... no big deal.
Old Feb 9, 2007 | 09:46 AM
Durango_Boy
I'm a cruiser so I'm all good.
Old Feb 9, 2007 | 09:50 AM
sly vette's Avatar
sly vette
Hey Matt,
Use the petcocks and just put a piece of tubing on them when you open them right into your catch can...no splash!!!
Add ALITTLE air pressure through a schrader valve at the spot where you blocked off the heater core and blow that bad boy out gently!!!
Old Feb 9, 2007 | 09:53 AM
Durango_Boy
Originally Posted by sly vette
Hey Matt,
Yep that sounds like a good way to do it. Spot on chap.
