Help: Fusible Link rating
Old Feb 9, 2007 | 12:40 PM
GlockGuy's Avatar
GlockGuy
Default Help: Fusible Link rating
Hi, I have not posted in awhile. Finally working on electrical problem on my 76. The FUSIBLE LINK from the fuse box to the ALTERNATOR blew and I need to replace it. What is the AMP rating for this link? Any one else have this happen?
I really appreciate the help.
Don
Old Feb 9, 2007 | 03:41 PM
GlockGuy's Avatar
GlockGuy
Called all the local Chevy dealers and they could not help me. Hoping to tackle this after work today.
Don
Old Feb 9, 2007 | 04:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I don't have specs for you,
I find an amp rated link at the alt rating
Old Feb 9, 2007 | 05:45 PM
GlockGuy's Avatar
GlockGuy
Thanks, well it seems that C3's do not use fusible links and that its a regular wire that shorted and burned through. I was told that fusible links were not used until the early 80's. Can anyone validate this?
Old Feb 9, 2007 | 06:27 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
not true
Old Feb 9, 2007 | 07:06 PM
Duke94's Avatar
Duke94
The wiring diagram for my 78' does NOT show a fusible link going to the alternator. There are 2 coming from the starter, but none to the alternator.
P.S: how about filling out your profile.
Old Feb 9, 2007 | 07:26 PM
noonie's Avatar
noonie
Researched this quite a while ago.
You probably won't find a direct rating. but the Rule of thumb is that you use 4 times the wire size.
12=20 amps, so a 12 ga fuseable link could be replaced by a 80 amp fuse element (a cartridge type fusible link)
Here is a good link http://www.autoshop101.com/forms/hweb1.pdf
Old Feb 9, 2007 | 09:50 PM
PhotoVette1's Avatar
PhotoVette1
There were 4 separate and distinct fusible links in my '77.
I replaced all my fusible links with auto-reset circuit breakers:
http://www.waytekwire.com/
Old Feb 9, 2007 | 10:04 PM
noonie's Avatar
noonie
Why did you use auto reset?
Old Feb 9, 2007 | 10:13 PM
PhotoVette1
I don't want it to loose power until I get it out of the road if I can possibly avoid it.
Also, just about all new cars use these auto-reset breakers, so that's what I did.
They won't re-close until the fault is gone, so if it was an intermittant fault, it will reset and I will regain power.
Old Feb 10, 2007 | 03:45 PM
GlockGuy's Avatar
GlockGuy
^done.
Thanks for the replies. So, 2 fusilbe links from the starter,
Photovette1, where were the other links located?
Old Feb 10, 2007 | 04:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The other two are 16gauge connected together at the end and attached to the starter via a crimped O connecter
To Help: Fusible Link rating
