changes to nitrous setup - track results...
Old Feb 9, 2007 | 08:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default changes to nitrous setup - track results...
Changed my nitrous setup so that I can either run it on a push button or for the entire run. Just wired a switch that would bypass the push button. Tried to make my first full nitrous pass today....
Here is a link to the results...
http://forums.corvetteforum.com/show....php?t=1620338
Old Feb 9, 2007 | 08:40 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
Man thats very cool.
Old Feb 9, 2007 | 09:06 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Arg, so close !! Hope it ain't hurt bad.
Old Feb 9, 2007 | 09:23 PM
GrandSportC3
If warming up the bottle wouldn't have taken so long, I MIGHt have gotten a run in sub 70 degree conditions.. When it was my time to run, it was just to hot for 9's.. Well, the next setup should be in the 9's on engine and 8's on spray.. We will see...
Old Feb 9, 2007 | 09:24 PM
GrandSportC3
well, except that I spun a bearing
Old Feb 9, 2007 | 09:38 PM
69 N.O.X. RATT
Ya, if that is all it did...it might not be that big of deal. A couple degrees of ambient temp is not worth .07 BTW.
Old Feb 9, 2007 | 09:43 PM
GrandSportC3
I recorded all my runs and the conditions.. I consistently get .07 to .10 for each 10 degrees lower temps... Don't forget that most of my engines power is on engine with only a small shot of spray... For example.. I ran 10.76 in 93 degrees and 10.35 in 62 degrees, 10.52 in 72 degrees etc. etc. etc... (those were all engine passes)
Calculating ET's for various conditions confirms my results...
http://www.smokemup.com
has plenty of calculators for DA etc...
Old Feb 9, 2007 | 09:58 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Like I said "It's the weak link finder." Great numbers though.
Old Feb 9, 2007 | 10:09 PM
69 N.O.X. RATT
Ok, but it is going to be a lot tougher to get now that you are getting faster.
Old Feb 9, 2007 | 10:19 PM
GrandSportC3
I don't think that it makes a huge difference.. I got the same difference in my 13 second C5... 13.39 in 50 degree weather and 13.89 in 93 degree weather... It might be slightly less as I get faster but I doubt that the difference will be huge.. However, if I will run a bigger nitrous shot, the difference will be less for sure..
Old Feb 11, 2007 | 11:01 PM
BLACK SHARK
OOOPs, Sorry, I ment cool about the ET.
Old Feb 11, 2007 | 11:02 PM
BLACK SHARK
Old Feb 12, 2007 | 07:15 AM
Twin_Turbo's Avatar
Twin_Turbo
Why a new topic? Are you afraid durango boy is going to catch up on your post count?
Old Feb 12, 2007 | 10:42 AM
GrandSportC3
The other thread is long gone
To changes to nitrous setup - track results...
