What is this sensor for??
Old Feb 10, 2007 | 12:12 PM
gleninsandiego's Avatar
gleninsandiego
Default What is this sensor for??
71 350 Auto
This sensor is on the passenger side of the engine. The wires that plug in it are currently disconnected. What is it for?
Old Feb 10, 2007 | 12:16 PM
Gordonm's Avatar
Gordonm
It is for the primative emissions that were on the car. It was a temp sensor to tell the system it was up to temp. It is not needed unless you are going back to dead stock with the car. It was hooked into the vacuum advance of the car and would not let the car go into advance until it was completly warmed up. Most if not all were not working within the first year of use.
Old Feb 10, 2007 | 12:17 PM
Engage's Avatar
Engage
Coolant temperature.
Durango_Boy's Avatar
Durango_Boy
I believe that's a water temperature sender.
Old Feb 10, 2007 | 12:24 PM
rcread's Avatar
rcread
Yep. I just plugged it when I put in my new heads. Water temp should be in the driver's side head unless someone changed it.
Old Feb 10, 2007 | 12:26 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
In 81's and 82's, this is an important part of the CCC. Your car won't run right with the computer without it. On your 71, it's a great way to plug the hole in your head. Unless you're trying to bring your emissions equipment back to stock, just ignore it.
The similar sensor on the drivers side, if your car is so equiped, is for the temperature sender.
Old Feb 10, 2007 | 12:27 PM
Big2Bird's Avatar
Big2Bird
On an 81 this is the fan control. The EC sensor is on the intake manifold.
Old Feb 10, 2007 | 12:32 PM
Lorin D's Avatar
Lorin D
Temperature sender , I had to replace mine, NAPA
there are a couple different senders , be sure to match
up one that your wire from your gauge to the sender
will fit .
Old Feb 10, 2007 | 12:35 PM
Durango_Boy
will fit .
His stock temperature sender would be in his driver's side head. I think a previous owner plugged the other side with a different sender.
Old Feb 10, 2007 | 12:37 PM
Steve's74's Avatar
Steve's74
This is actually the correct answer. It is the temperature sensor for the TCS (transmission controlled spark) emission system. Unless you have spent a lot of time to restore the complete system, it probably is no longer useful.
Steve
Old Feb 10, 2007 | 12:40 PM
Lorin D's Avatar
Lorin D
Default What is this sensor for ??
Should have check first, mine is on the drivers side .
Shows to go ya.... check first , make a comment second. SORRY
Old Feb 10, 2007 | 12:42 PM
theandies's Avatar
theandies
Steve
Yup TCS. The coolant gauge sensor on a 71 is in the drivers side head. The TCS temp sensor is in the passenger side head.
Old Feb 10, 2007 | 12:52 PM
Steve's74's Avatar
Steve's74
Hey John! Ready to come down to Harrisonburg and twist some wrenches?
Old Feb 10, 2007 | 12:53 PM
Big2Bird's Avatar
Big2Bird
Good advice.
Old Feb 10, 2007 | 01:21 PM
Paul L's Avatar
Paul L
That is the TCS. In later C3 years the sensor controlled the optional auxiliary electrical fan.
Old Feb 10, 2007 | 02:09 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Just to clarify, on a 71 the pass side is the temp sender for the TCS override. TCS kills vacuum to the distributer vacuum advance unit unless the transmission is in high gear or when the engine is cold or starting to overheat. The pass side sender tell the TCS system what the engine temp is. Driver side is the temp guage sender.
Old Feb 10, 2007 | 02:45 PM
Duke94's Avatar
Duke94
Not all 71's had the xtra temp sensor in the right head. My 71' did not. Here is an NCRS article on the TCS system. Back then, GM did whatever they felt like doing regarding engines and emissions.
http://ncrsrmc.org/Downloads/Mar-2006-Newsletter.pdf
Old Feb 10, 2007 | 03:10 PM
gq82's Avatar
gq82
Interesting reading Gary, thanks. I've never seen only one sensor on a 71 but I also know anything is possible. Does your one sensor do double duty?
Old Feb 10, 2007 | 04:02 PM
Duke94's Avatar
Duke94
No, it doesn't use temperature at all. Just have to be in 4th gear.
To What is this sensor for??
