Chasing erratic misfire
Old Feb 11, 2007 | 01:38 PM
noonie's Avatar
noonie
With 3&5 only, being consistantly much leaner I would think
-vacuum leak in runners perhaps on bottom side?
-valve problems, not seating etc, leakdown compression tests?
-switch plug wires to test wires?
-hei pickup coil, test with other dist?
Doubt if it is a carb problem
Old Feb 11, 2007 | 02:38 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by Big2Bird
Paul, You did run a new wire, right?(Have to ask)
I actually have changed out the wires twice since this saga began.
Old Feb 11, 2007 | 06:10 PM
Big2Bird's Avatar
Big2Bird
Not the wires. The primary 12v wire. Just making sure you don't have a ballast/ resistance wire in the circuit.(gotta ask)
Old Feb 11, 2007 | 06:11 PM
Big2Bird's Avatar
Big2Bird
My vote.
Old Feb 11, 2007 | 09:56 PM
SanDiegoPaul
No just using OEM wiring to the new dist. The car came originially with HEI 'cause it's a '76.
Old Feb 11, 2007 | 10:05 PM
Big2Bird's Avatar
Big2Bird
Then my vote is with Noonie. I doubt it's valvetrain on adjacent cylinders. You've virtually eliminated ignition and fuel. I sure would like to hear more from the other motorheads first.
Old Feb 11, 2007 | 10:20 PM
mr303's Avatar
mr303
Sounds like you should put on some beers and get the local guys around to have a look, you never know what they might see! It could be a cheap fix. Good Luck.
Old Feb 11, 2007 | 11:40 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Broken valve spring(s)?
Old Feb 11, 2007 | 11:49 PM
King Lear's Avatar
King Lear
Veteran
My 72 was doing misfire for a good time. I replaced the entire ignition system. Nothing. It turned out to be the timing chain. I replaced the chain and pulleys with a double roller chain and my problem was gone. The gears were worn on the original timing gear and was slipping in the same spots. Once I put in the new timing set & chain we were good to go. 6000+ Rpm today and not a single misfire. I have some oil problems but that is another story! If you already replaced this then I missed it in the posting. Hope it helps.
Old Feb 12, 2007 | 11:02 AM
SanDiegoPaul
When the engine was built, I used a Cloyes double roller set.
Old Feb 12, 2007 | 11:41 AM
King Lear's Avatar
King Lear
Veteran
Well by the sound of everything and its not the chain. I would say the only thing left would have to be the point of contact between the cam and the distributor. That is the only other thing I can think of that hasn't bee mentioned.
Old Feb 12, 2007 | 12:29 PM
7T1vette's Avatar
7T1vette
Here's a long shot idea. You said that the stumble is when the car is stopped and idling in "drive". Have you checked the problem when it is in gear? The idle drops a few hundred RPM when in gear...maybe there is some voltage drop at low idle that is affecting the ignition (really grasping for straws here). If you have an induction pickup timing light, have your wife hold the brake while the car is in "drive" at idle; put the pickup on the cylinder wires you are concerned with and see if the flash is erratic. If it is, have her just give it a touch of throttle to see if it goes away. If so, test the system voltage at each condition.
Remember...I said it was a long shot. Good luck.
Old Feb 12, 2007 | 01:23 PM
  #33
454_71Stingray's Avatar
454_71Stingray
Have you adjusted the valves? I did one adjustment out of desperation on my old Chevelle and it fixed the miss fire I had. Just my .02
