Control Arm questions
Old Feb 10, 2007 | 06:37 PM
BBNJKen's Avatar
BBNJKen
Default Control Arm questions
I've done a few searches, didn't see the answers to my questions, so here goes.
Looks like I need a new upper control arm shaft, as one end of one of them has been chewed up by the inner sleeve of the stock rubber bushing.
So far, all I've found are control arm shaft kits, with HW I don't need. Any one know of a source of just the shafts, besides GM?
2nd question is for those that have installed poly bushings, as I plan to do. Once installed, exactly what part rotates, and stays put? Is the "joint" between the poly part and the inner sleeve, or the poly part and the outer sleeve?
Thanks in advance
BB NJ Ken
Old Feb 10, 2007 | 06:43 PM
Duke94's Avatar
Duke94
Van Steel.
http://www.vansteel.com/vansteelcatalog23.pdf
