Spring Installation
Old Feb 10, 2007 | 10:41 PM
willem wallace's Avatar
willem wallace
Default Spring Installation
After to much time prepping I am finally into the reassembly phase of a frame off on a 1971 roadster. This is a first time car project for me so I am in need of some advice on spring installation. I am replacing the stock GM springs with a set of 460 lb. VBP coils(383cu.in.,auto,no a.c.). Frame is naked of parts, and I am starting front suspension reassembly with the rebushed upper and lower control arms. What is the easiest way to install the shorter VBP 460 springs. Any info is appreciated.
Willem
Old Feb 10, 2007 | 11:19 PM
shafrs3's Avatar
shafrs3
Since they're shorter I don't think you need a spring compressor, just put the spring up in the frame pockets and attach the two A-arms together. If this won't work then use a spring compressor.
Old Feb 10, 2007 | 11:29 PM
lars's Avatar
lars
Without the weight of the car to work with, you will have to use a spring compressor. If you had a complete car with engine, you could get by without a compressor using the weight of the car to bring the lower arm up. But with a bare frame, you'll have to use the spring tool.
Old Feb 12, 2007 | 02:09 PM
Jim71Vette's Avatar
Jim71Vette
Why not wait until you put the engine back in? That what I plan to do.
Old Feb 12, 2007 | 05:10 PM
GTR1999's Avatar
GTR1999
I made a compressor out of acme threaded rod and nuts. I welded one end on the rod to use as the cranking end. Thread it through the shock hole and the spring and use a 5/8 -3/4 steel plate with a hole in it to lock under the control arm and compress the spring.
The acme thread is what is used on jacks and will be more then enough, I think I used about a 3/4 diameter. www.mcmaster.com will have it online.
Got the idea from Chuck over in c2 and changed from all thread to acme rod.
Old Feb 12, 2007 | 05:19 PM
Bob3700's Avatar
Bob3700
Default Front Springs - no motor
For front spring without a motor - first do you have a floor jack? How about a piece of stout chain (about a 3/8" will do).
You can put the chain under the floor jack axle, loop the chain up over the frame. You have now made a tool to compress your spring.
Tip: Run the chain through the spring and keep it taught. This will make the floor jack compress the spring sooner and contain the spring.
Not the most elegant solution but works just fine.
Bob
To Spring Installation
