just installed the steroids rack and much more this week. and on my 79 vette the roids rack sits higher up then the old stuff see picIMG]http://i126.photobucket.com/album<a href="http://photobucket.com/" target="_blank"><img src="http://i126.photobucket.com/albums/p119/tellcom2001/rack.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>s/p119/tellcom2001/rack.jpg[/IMG]
you need to recenter the rack, look at how much the pass side rod end is out, that's dangerous, you need to recenter the rack before hooking up the column, you need to measure from the tie rod holes on the center bracket to the cross shafts and those measurements need to be the same left and right
they all charge almost the same i went with vbp. and got mono coils new upper a arms and bilstein shocks. looks great and droped the nose down an inch. and the rack was just installed not adjusted when i took the pic. will test drive the new rack on thursday. also installed new mono rear spring with adjustiable strut rods and bilstein shocks. should drive awsome. ill let you know as i drive it like i stole it.
