Rich:
where's the CORRECT LSA????? ... that's from mfg ... you input LSA ... calc does NOT return it ... you input that.
Also ... what ICL is it ACTUALLY installed at?
Also ... add about 2*-3* to duration when running 1.6:1 RAR.
It is installed at ICL 107, LSA is 112. Crane doesn't put ICL on there cam card, it is labeled as 107 max lift but it is the same, I found this out on Cranes tech web site last night. changing to 287/295 duration changed everything. Drops DCR to 7.68. Moved all the seat values 1.5. Using comp cams desktop dyno advanced it gives me an overlap of 67. Also the desktop dyno numbers match the the GOOD DCR calculators cam calculations perfectly. According to the desktop dyno I should hit 524 HP @ 6000 RPM and 507 TQ @ 5000 RPM. Somehow I think that is a bit high myself.
I ran it but added 2* to dur (286/294) and 112 LSA & 107 ICL ... returns 70* ICA & 7.1867....dcr.
Just for kicks I figured out what my builder has it at right now before he changes heads, gaskets, etc. I am at a power building 9.31 static and DCR of 7.26. This is exactly what you said before Jackson, many a turd motors have been made using the KB figures. He went off of Eagles catalog figures, oh well, at least he is fixing his errors and is going to make it right once the snow goes away!
I downloaded the DCR Calculator, but there must be something wrong with the code.
If I set all values and then calculate my static comp I get 11.3 (KB 11.2) so far everything is ok.
But when I then checks the box for dyn comp and refresh I always get 9.3 It doesn't matter what IVC timimg I set, and even if I change the cam values totaly, it gives me 9.3 in dyn comp.
I cannot seem to get it either. My SCR is 9.971 and when I check the box for dynamic stroke, it only changes it to 9.405. It is with the Crane Powermax 272 (272/284; 107 ICL? and 112 LSA)
There must be a bug in that pgm!
What piston are you running? Trust me, I have been through every dcr calc out there, it is flawless compared to anything out there!
i was having the same problem and realized i was putting the wrong numbers in. i was was using .050 numbers instead of the seat to seat numbers. i am comming up with 7.9 dcr now. i was using 44* abdc instead of 69* in mine. also once again if you were to add 15* to the 44* abdc figue at .050 it comes out to 59* so that explains why i was not able to make sense of the other calcs having such high dcrs. that kb calc is crap. thanks to a quick reply from jackson i figured out what my problem was when i looked at my cam card a little closer.
King Lear can you take a look at my cam to?
I'm using the 0.015 numbers, but is that wrong?
I'm running flat top Probe SRS pistons, with a Trick Flow 64 cc head.
I have a Comp Cams XE274 12-770-8 but I'm looking at a XE280 just to bleed of some dcr.
I just ran your #'s and came up with a dcr of 9.10889868621097 and static CR of 11.2609317466645.
My only question is the deck clearance you give is .015. Are you sure this number is correct? The builder should have the deck clearance documented for your build. If you went to a .040 head gasket you will be at 8.8 dcr and 10.9:1 SCR. However, you have a nice trick flow aluminum head. The aluminum head cools much more rapidly then an iron head. Therefore, depending on opinions an aluminum head reads about .5 CR lower internal engine signal then an iron head. So with this in mind your 9.1 dcr is actually reading as a 8.6 dcr in engine signal. So in theory you should be fine!
Havn't milled the deck yet, plan is to have 0.015.
I will yse a 0.029 gasket.
Did you use a 0.039 gasket to get these numbers?
If I retard the cam 4*, how will this affect the dcr?
Anyway I have decided to go for the bigger XE280 cam, just to be on the safe side with the dcr.
If I type in the XE280 values, I get the same dcr, very strange!
Should change, as the IVC is different!
Ok, Thanks for those that offered to help! Her is my info: Crank Stroke 3.75, Rod length 6", ADV intake closing angle ??????? Intake duration 287, exhaust duration, 293, LSA 114, ICL 110, Int. Open 8, Ex. Open 59, int. closed 48, ex. closed 3, Bore diameter 4.030, stroke 3.75, head CC 74, gasket thickness .040, gasket bore 4.060, deck height 0.00, flat top pistons with 5 cc valve relief, quench .040. If any more info is needed let me know! If possible check advanced 4 and retarded 4. Thanks Kevin
