Full length header fit ('80)
Old Feb 11, 2007 | 10:49 PM
MN80Vette's Avatar
MN80Vette
Default Full length header fit ('80)
There have been a lot of threads about dual exhaust, headers, etc. I switched from block huggers to full length ceramic this summer because the block huggers melted my motor mounts and I had to remove the headers to get at 2 spark plugs
When I was shopping for headers, fit was my #1 criterion. I wanted good clearance around the motor mounts, clutch linkage, starter, oil filter, spark plugs, and Steeroids u-joint chain.
I bought a pair of Dynomax BlackJack headers from Summit because they appeared to have a nice rearward sweep and stood out from the headers to clear the spark plugs.
I think I made a good choice - as the pictures below show. (Ignore the brake fluid all over the frame below the m.c. )
Clearance is OK too. If the headers hit, I've got bigger problems.
Old Feb 12, 2007 | 08:50 AM
ESU's Avatar
ESU
Just picked up a set of dynomax ceramic coated off ebay for my 79. Price was right and from what I've heard on the forum theyre supposed to be decent headers. Cant wait to get them in.
Old Feb 12, 2007 | 09:27 AM
okinawa86vette's Avatar
okinawa86vette
Something to consider as far as the plugs go is modifying a plug socket.
I took a shorty style plug socket, the kind with a hex end so you can turn it with a wrench (shorty wrench helps here too), and cut one of the six sides out with a cutting wheel. You don't even need to remove the whole side, just enough to be able to slide the socket sideways over the plug. That way, if the header goes in front of the plug, you can still get to it. The tool's a godsend and it's one of the few tools I would be really upset about if I lost.
I can replace all 8 plugs on my 72 (with headers) in about 15 min.
C
Old Feb 12, 2007 | 09:28 AM
UKPaul's Avatar
UKPaul
Well happy with the fit of Dynomax Headers on my '81
Old Feb 12, 2007 | 12:37 PM
C3 4ME's Avatar
C3 4ME
I have Hooker Super Comps on my 79 4 spd and they fit just fine, so there's another suggesiton to someone who might be looking. I just sent them off for ceramic coating the other week.
Old Feb 12, 2007 | 01:42 PM
79-L-82's Avatar
79-L-82
I've been shopping around too.
the Hookers seem pricey for normal headers.
How much is the ceramic coating going to run you?
Old Feb 12, 2007 | 05:54 PM
OregonVette80's Avatar
OregonVette80
Yep...G O O D !
Going to take it to the dyno to see just how good too!
http://www.stans-headers.com/tri_y.htm
BTW...Noticeable difference already!
Old Feb 14, 2007 | 10:13 AM
ESU's Avatar
ESU
My headers should be here friday, just curious if they go in easier from the top or bottom?
ESU
Old Feb 14, 2007 | 11:33 AM
jtp75_4spd's Avatar
jtp75_4spd
Default long tube header exhaust system question.....
I have a 75 that has also has a long tube header, believe it is a black jack (dynomax), the exhaust pipes, muffler are pretty crappy.....Question: is there an exhaust system (pipes, mufflers) available that will bolt up to these or do do all u guys have a exhaust shop custom make a system for your vette???? thnx for any info........
Old Feb 14, 2007 | 08:11 PM
MN80Vette's Avatar
MN80Vette
I started with a ready-made pipes and separately purchased mufflers. The fit was pretty bad - the pipes scraped on almost any little bump. The muffler shop I took it to said it would cost more to adjust the bends than to just bend custom pipes in the first place, so I just scrapped the kit pipes. Custom bent pipes are the way to go BUT make sure you go to a shop that bends pipes for Corvettes, muscle cars, and hot rods regularly. You don't want your car to be their experiment.
Old Feb 27, 2007 | 09:03 PM
Cignificant's Avatar
Cignificant
MN80Vette - was the part number of the Dynomax's WLK-86008? I'm guessing I'll get blasted for this question, but will they work with the AC bracket or will I need to fabricate something?
Old Feb 27, 2007 | 09:30 PM
ESU's Avatar
ESU
These r the ones i just picked up. U need to make a short spacer for the a/c, 3/8 tubing i think,
ESU
Old Feb 28, 2007 | 12:14 AM
MN80Vette's Avatar
MN80Vette
Yes, that's the part number, but I don't know about the AC bracket. I didn't install the AC compressor when I replaced my engine. Sounds like ESU can help you.
Let us know how your headers project goes!
Old Feb 28, 2007 | 08:52 AM
marshrat99's Avatar
marshrat99
Recently I posted my experience on installing Hedman Elite's on my 79. I bought the AC adapter that was recommended but it DID NOT work. After eye-balling the application over a couple of brewskies, I ended up just fabbing a spacer using a 1/2" OD x 1 3/8" steel pipe between the header and the AC bracket. Of course at this point I also reused the original #2 cylinder exhaust manifold bolt.
Old Feb 28, 2007 | 10:04 AM
ESU's Avatar
ESU
I havent installed mine yet, gonna wait to see if I sell the car first and save them for the next ride. That being said most people wind up fabbing some type of spacer as Mashrat did.
ESU
Old Mar 1, 2007 | 06:50 AM
Cignificant
It's a little more than just headers. New suspension, differential, tranny, engine... the list goes on and on. But I'm getting to the point where I think I might actually hear it run again!
Any comments on the new exhaust system being offered by Pypes?
http://www.pypesexhaust.com/sys-vette1.html
Old Mar 1, 2007 | 08:28 AM
jtp75_4spd's Avatar
jtp75_4spd
Default Is that pypes system set up to bolt to >>>>
Is that pypes system set up to bolt up to the shorty block hugger stock style headers or is it set up to bolt up to long tube headers??
To Full length header fit ('80)
Old Mar 2, 2007 | 02:28 PM
Cignificant
I called, they said they're made to connect to long tube headers.
Old Mar 2, 2007 | 02:59 PM
jtp75_4spd's Avatar
jtp75_4spd
Good news!, thnx for the info.....
I notice their website says $599 available in April....with a $487 introductory price...also says "* some cutting may be required"........nice custom fit system!!!
Wonder if anybody has ordered??, my long tube header exhaust system is pretty crappy hangs real low, loud as hell at idle!!!!! (but just bought car and is in storage 2 hours away so only going on the memory), so it is tempting to have the X cross tube which should be better than straight duals......anybody thinking about getting this system????
Old Mar 2, 2007 | 03:07 PM
Cignificant
Well, the web site says April, but their production group says "maybe June/July". I'm going to look for another option...
