Dim dash lights, LEDs?
Old Feb 12, 2007 | 04:02 AM
Robert Potter's Avatar
Robert Potter
Default Dim dash lights, LEDs?
My dash lights on my ’82 are very dim. Has anyone changed to LEDs. Any ideas?
Old Feb 12, 2007 | 10:19 AM
Durango_Boy's Avatar
Durango_Boy
Several have, yes, but the bulbs may not be your problem. Two things can happen giving you dim lights. Burnt out bulbs or a bad dimmer switch.
Your ground may be bad as well but that would cause intermittent blackouts.
I would start at the switch.
Old Feb 12, 2007 | 12:02 PM
White 68's Avatar
White 68
Read this thread about half way down bluthunder has a link and order numbers for superbrightleads ....
http://forums.corvetteforum.com/show....php?t=1620458
http://www.superbrightleds.com/
Old Feb 13, 2007 | 11:35 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Also, incandescent bulbs go bad over time. Even if they still work, they get dim.
Old Feb 13, 2007 | 11:56 PM
Big2Bird's Avatar
Big2Bird
There is a thread on this in C-3 general right now.
The dim could be caused by numorous things.
Low voltage
Wrong lamps
Nicotine film
Dirt/dust
Old age/Bulb darkening
Wiper contact on dimmer bad
Resistance in the ground return path
Although I have no plans to change to LED's at this time, they do promise 50 times lamp life. A plus when talking about the hard access sometimes to certain lamps.
Old Feb 14, 2007 | 10:41 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
When I rebuilt the interior on my '76 it also got all new bulbs. Didn't affect the brightness of the dash at all at night. It is just a dim design and I think the LED solution would be great. As long as they work with the original setup.
Old Feb 14, 2007 | 10:47 AM
Durango_Boy
The LEDs work great and the dimmer...which I think is bad, will work with the new LED bulbs just fine. If you get all white for the lights, blue for the bright, red for the brake, and green for the signals...it all works well and looks great when finished.
That being said, I think you should look into a new headlight/dimmer switch or you may not think the new LEDs are bright enough either.
To Dim dash lights, LEDs?
