Dash Electrical Problems
Old Feb 12, 2007 | 07:35 PM
Hybrid117's Avatar
Hybrid117
Default Dash Electrical Problems
Ok so my tach is not working. Its plugged in to my HEI but i get nothing on the tach. Burned out circut bord? Troubleshooting ideas and is this a do-it-yourselfer?
ALSO
I broke my dimmer switch. It will pull up my headlights but when i turn it, the **** just keeps goin so i think i broke off something turning it. Is this something i can fix myself with a little fabrication or glue? Should i just buy another?
Old Feb 12, 2007 | 07:38 PM
Durango_Boy's Avatar
Durango_Boy
Buy a new switch. Cheap at local parts stores, and not too hard to install. Post a thread when you have it and are ready to install it.
Old Feb 12, 2007 | 08:25 PM
Kilroy1024's Avatar
Kilroy1024
The official Vette headlight can sometimes be hard to find.
The only real difference is the vacuum switch for the headlights.
I bought a Camaro switch and moved the vacuum switch over.
It was even cheaper and easy to find.
Old Feb 12, 2007 | 10:37 PM
Big2Bird's Avatar
Big2Bird
There is a guy on E-Bay who sells them regularly.(Switch)
Old Feb 12, 2007 | 10:48 PM
SEVNT6's Avatar
SEVNT6
Check your tach filter first and make sure it has a good ground and the wires are connected tight.
Old Feb 12, 2007 | 11:06 PM
Artsvette73's Avatar
Artsvette73
Gm used these switches for years. Yes you have to change out the vac portion to the new switch.
Old Feb 13, 2007 | 11:14 AM
Durango_Boy
The Camaro switch was the same and cheaper? What year was this for?
Old Feb 13, 2007 | 01:30 PM
Hybrid117's Avatar
Hybrid117
my 1980
Old Feb 13, 2007 | 05:07 PM
saudivette's Avatar
saudivette
...I bought a Camaro switch and moved the vacuum switch over...
I bought a C4 switch, converted the lights to electrickery and DELETED the vacuum
Old Feb 13, 2007 | 05:40 PM
Durango_Boy
Quit bragging.
Old Feb 13, 2007 | 05:48 PM
saudivette's Avatar
saudivette
Moi?
Old Feb 13, 2007 | 06:29 PM
Hybrid117's Avatar
Hybrid117
Its not the headlights, i have no light in my gauges or anything. The headlights work fine i just can see how fast im goin when its dark outside.
Old Feb 13, 2007 | 06:36 PM
Durango_Boy
My money's still on the headlight switch.
Old Feb 14, 2007 | 08:57 AM
Big2Bird's Avatar
Big2Bird
Safe bet
Old Feb 14, 2007 | 10:05 AM
saudivette's Avatar
saudivette
If ALL your dash lights aren't working, and it's not a fuse, then I'm sticking with the switch.
Just swap the switch out with another and see what you get. I would imagine that you wouldn't even need a Corvette switch for trouble shooting. I could be wrong (and frequently AM) but any Chevy headlight switch from the same era would probably fit. Even a C4 switch will fit so you can trouble shoot the dash lights
Old Feb 14, 2007 | 10:49 AM
Durango_Boy
Testing is your first choice. If nothing changes then return it and search for a different path.
Old Feb 14, 2007 | 10:51 AM
Big2Bird's Avatar
Big2Bird
Most stores do not accept returned electrical items.
To Dash Electrical Problems
Old Feb 14, 2007 | 11:17 AM
Durango_Boy
True, but they won't know it's used. Just say, wrong application.
Old Feb 14, 2007 | 03:45 PM
Kilroy1024's Avatar
Kilroy1024
My Vette is a 76 and I could not find a a head light switch anywhere in town.
So... I asked to see a 76 Camaro headlight switch.
Its pretty much the same without the vacuum actuator.
Old Feb 14, 2007 | 03:46 PM
Kilroy1024's Avatar
Kilroy1024
Mine too. The dash dimmer coil is probably broken.
Its all wrapped up into the same switch.
