engine knock
Old Feb 14, 2007 | 06:15 PM
copter's Avatar
copter
Sometimes a blown header gasket can sound like major engine problems also.I to would like to know how your oil pressure is.If you drain the oil put in one can of slick50 with your favorite brand of oil and see if that does anything.
Old Feb 14, 2007 | 06:38 PM
CurtH's Avatar
CurtH
Originally Posted by genuine1980
I'm not arguing, but I've never heard of this before....
The oil pressure on my vette goes down at idle and up with rpm... and I have no rod bearing issues with it.
I also had a rod knocking on my truck and never noticed the oil pressure doing anything out of the ordinary as the oil pressure goes up and down on this depending on rpm too... even before the rod issue.
On my 99 Camaro same thing.... no rod bearing issues, but the oil pressure goes up and down with rpm.
Is the oil pressure changes somehow differnet than what you might see normally?
I should have said, At a hot idle if the oil pressure drops below 15lbs & builds up to 35lbs or better when you rev up the engine, thats a good indication of a bearing issue.
Old Feb 18, 2007 | 02:46 PM
Smoke 1's Avatar
Smoke 1
Default knocks
Thanks to all for the suggestions. I have pulled the spark plugs, no change in the knock/dinging. I have examined the fly wheel,and torque conv. bolts, no cracks or loose bolts. I have also examined the tension on the rods, made some slight adj. with no avail. I will keep looking. Thanks again
Old Feb 18, 2007 | 03:10 PM
noonie's Avatar
noonie
That was completely normal for these chevy engines back then. As long as the oil was regularily changed, they would easily last 100,000.
I can't remember 1 out of many that wasn't like that.
Old Feb 18, 2007 | 06:25 PM
SmokinBBC's Avatar
SmokinBBC
Is the noise coming from under the valve covers?
How does it sound underneith the engine?
Is the noise in the waterpump?
Unless you can isolate the area of the noise, it could be almost anything. If you are having a hard time isolating the noise, use a small length of garden hose with one end attached to the end of a funnel. Put the funnel to your ear and move the hose around the engine until you isolate your noise.....yes, it looks funny, but it works.
Old Feb 18, 2007 | 06:39 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
Originally Posted by juiceman03070
With so many metal to metal parts making contact ...Ive had a faulty mechanical fuel pump sound like a busted wrist pen..
same thing happened to me.
