Cam shaft questions
Old Feb 13, 2007 | 10:27 PM
1427's Avatar
1427
Default Cam shaft questions
Who knows of Cam Manufacturer that has roller cam configuration similar to L88 grind?
Old Feb 14, 2007 | 01:54 PM
User 81424's Avatar
User 81424
Welcome!
This section is for help with the forum itself. Your thread will soon be moved to the C3 section.
Old Feb 14, 2007 | 09:09 PM
Little Mouse's Avatar
Little Mouse
If I remember right the solid flat tappit L88 cam had 560/580
lift and a lot of duration. I don't think you will find and off the
shelf solid roller with the dur. figures close to what it had and
anywhere near that low of lift the lift will be a lot higher. Cam companies will make anything you want.
To Cam shaft questions
