Cam replacement Question: A/C coil
Old Oct 6, 2001 | 06:44 PM
1979toy's Avatar
1979toy
Default Cam replacement Question: A/C coil
I've got my engine apart, hood off and radiator removed but I can't tell how to move the A/C coil out of the way without disconnecting it. Can someone shed some light on this please?
Funny how a header change can grow into a cam, cylinder head, and intake swap :D
Old Oct 6, 2001 | 06:57 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Cam replacement Question: A/C coil (1979toy)
Grab the coil on the drivers side and gently lift up. the hoses will tilt up as you lift the coil. It's a two person job, but you will be able to lift the drivers side up just above the point that the cam will slid in. good luck.
Old Oct 6, 2001 | 09:00 PM
1979toy's Avatar
1979toy
Default Re: Cam replacement Question: A/C coil (Paul 75 L82)
Yep! It spun out of the way just as you said it would. Thanks Paul.
Like to guess how long I spent trying to get either a 3/8ths or 7/16ths on the METRIC lower bolts on the A/C coil? :mad
To Cam replacement Question: A/C coil
