cable driven tach not working
Old Feb 14, 2007 | 01:04 PM
blue by you's Avatar
blue by you
Default cable driven tach not working
Can anyone tell me on a cable drive dist hoe the brass button goes in and what it does. I would like to fix my tach.
Old Feb 14, 2007 | 01:12 PM
lars's Avatar
lars
You have to machine the inside of your distributor housing to accept the brass button. Some later tach drive distributors used a nylon thrust button, and these distributors have a hole in them to hold the nylon piece in place. The brass buttons have a stem that is larger than the hole for the nylon piece, so you have to open the hole up. The diameter of the brass button is also too big to fit in place of the nylon part, so you have to turn it down. On the distributors without the nylon button and hole, you first have to machine out the damaged area on the thrust surface and create a couterbore for the new thrust button to seat into.
By the way - I have had poor luck with the brass buttons - they get chewed up pretty quick. I've been machining steel inserts for the thrust surfaces, and that holds up much better.
Old Feb 14, 2007 | 01:19 PM
blue by you
Lars, thanks for the info I think I'll order the nylon button and try that. It's a 71 and acording to the paper work I found the tach hasn't worked since 72. I did get it to work for about 2 days so I know I missing something.
Old Feb 14, 2007 | 01:21 PM
lars's Avatar
lars
If the tach is not working, the thrust button will not fix it. You either have stripped teeth on the crossgear and mainshaft or a broken cable. If the teeth are stripped, you need to replace the mainshaft, crossgear, crossgear bushing, and you need to repair the thrust surface wear inside the distributor housing (or else the gears will lock and strip again).
Old Feb 14, 2007 | 02:34 PM
blue by you
Lars, does the plastic button pop into the hole in the dist housing, I think the problem is that I had a brass button and I just put it in not realizeing how it all worked. I'll order a plastic one and look at the teeth in the dist.It hasn't worked since 72 only being 1 year old do you think the teeth could be shot?
Old Feb 14, 2007 | 02:50 PM
lars's Avatar
lars
The thrust button has no effect on whether or not the tach works - it only provides a thrust surface for the crossgear. If you have a brass one in there now, the nylon one will not change things. If the tach is not working, you have a broken cable or stripped gears.
Old Feb 14, 2007 | 04:31 PM
carl a's Avatar
carl a
i waisted so much time (3 tach drives gears)and money on the origional dist, i went with the msd tach drive and ended all those tach drive problems
Old Feb 14, 2007 | 05:05 PM
GTR1999's Avatar
GTR1999
I too had the same problem with the gears and shafts on the market. Bought from several vendors got the same crappy part from each one. The ones I got were not machined correctly to mesh with the shaft. I even went as far as machining the brass plug out and installing a new one that I faced off a few thousands at a time - still ng. I returned them all and not one supplier could offer me an explanation- because they didn't know either. I found a goo dGM gear and it's working to this day. The only gear I'd trust is from Hy Tech in FL if they're still in business?? I heard the owner passed away unfortunately.
Old Feb 15, 2007 | 08:06 AM
blue by you
Ok thanks. Looks like I got some work to do.
To cable driven tach not working
