Is it standard practice to use an agle grinder and grind on the crankshaft to remove mass for balancing purposes ??? I mean, not that it really matters but it sure looks ugly
Generally the counter weights are drilled. The flat area will cause a small amount of drag (that's why the counter weights are knife edged). Strange way to do it, but on a street engine should be OK. If this is a race engine, you're screwed.
I don't agree that on a race engine, he's screwed. It may not be the pretties way, may cause a bit of windage but I'd bet there's not a horsepower difference between one ground like that and one that's been drilled. As long as the shop has a good reputation and all dimensions are good, run hell out of it.
here's the beautiful job my machine shop did with mine....they said it was way out of balance, but they definately could've done a better job.....my motor's been running for about 4 months now....
Are you sure this is not pictures of craters on the moon.
I would rather they take the angle grinder to mine than do that! Mine was drilled but looks way prettier. Who is the manufacturer of the crank?
Mine is drilled too.... I expected it to be drilled that's why I didn't mention it or posted pictures of the holes..... I also think that if you grind on the crank you can polish it a little and make it look a little nicer, especially if you sell a short block without oil pan to hide the half a$$ job....
bluegtp - although it's likely going to run fine.... that's fugly...... people just don't take pride in their work nowadays. I'd be ashamed giving a crank like this to a customer :o
I hope that's not as ugly as it looks in the picture. Any sharp edges will create stress risers, and stress risers create cracks, and cracks create broken parts, and broken parts create...........
Same for taking a grinder and removing metal. As long as it's polished afterwards, no problem.
